No need to spring to the designer's defence, Orb, I'm not having a go at them. Ultimately everything that is built by man has some compromises as part of its package, otherwise it becomes hideously expensive, or ugly, or not approriate for its intended usage. I'm sure the Devialet's engineers are highly competent, they are obviously inspired in many areas of its topology.People hear improvements with various well engineered established high end audio amps/dacs/etc when using cables-filters, you going to suggest the same about those as well?
I hope this is not coming off strong but it is a bit reckless to make that claim Frank without all the information, especially when people will read it and then assume the power supply design is flawed or corners cut, which IMO is not but either way we do not have the facts to make that claim seem so strong.
If there is a limitation regarding this side, it is the smaller powere reserve compared to larger amps and the implementation of capacitors.
To me D-Premier does not compare to those amps with much greater reserves when dealing with dynamic swells, it does well but not as good.
For some this will not matter as it is better than a single D-Premier, for some others they want the full sensation of those dynamic swells that they hear from the big amps.
But you yourself have indicated where a very specific compromise has been made, which has a direct effect that you're aware of. From my experience with playing with quite a few power supplies in audio gear every effort has to be made to allow these to work with the least interference and stress possible, so adding something on the outside improving things tells you that more filtering on the inside of the unit could have been done.
There is a big difference between a compromise and an engineering "flaw" ...
Frank
