Expensive fuse or circuit breaker?
Gregadd
1,790
1,850
Metro DC
For the most part the toroidial transformer has replaced the traditional wax and paper transformer. There are some classic designs that cling to the latter. I I lack the technical expertise but I see no reason why we should still utilize fuses. In deed if you already own equipment it may be good idea to have it modified for coircuit breakers. This is especially true since it seems my fuse always blows at night or on the weekend when the store is closed.
What say you?
DasguteOhr
2,442
2,621
645
Germany
So if the fuse blows, it is usually technically defective, or the fuse is not correctly dimensioned. fast, medium slow and slow blow important.
these circut breakers have a heating coil similar to a coil, they have a magnetic effect which is very undesirable in audio equipment. Many manufacturers want more and more non-magnetic parts, e.g. ressistors. I wouldn't do it because I don't trust the trigger characteristics.
Exsample Circut breaker
Reactions: Gregadd
Gregadd
1,790
1,850
Metro DC
American ingenuity. Sounds like a solvable problem.
DasguteOhr
2,442
2,621
645
Germany
I use something in the AC 230v power like this, in devices fuses from them. i love non magneting things;)
Reactions: carolus
Folsom
6,032
1,503
550
Eastern WA
Sure don't use a fuse. When your device that only uses 2A goes to 10A and doesn't trigger tripping/clearing a circuit breaker and fries the device... you know who to blame.
BlueFox
1,709
407
405
What say you?
I assume you are talking about a piece of stereo gear. If the fuse is blowing while the gear is idle then you have a problem. Better to find and fix the problem than modify the gear to not use a fuse.
DasguteOhr
2,442
2,621
645
Germany
i think you got it wrong or my english is bad. I use this Ahp module instead of a circut breaker in electrical distribution. It has the German VDE approval which which has very strict rules.
Reactions: carolus
Gregadd
1,790
1,850
Metro DC
Yes I am.
IME when the fuse blows, it is because I have exceeded the power limit or there is a short circuit(loose cable or wire).
Gregadd
1,790
1,850
Metro DC
DISCLAIMER​
I am not advising anyone to modify their equipment. Doing so could void your warranty or possibly cause catastrophic failer. I am just wondering is that the general direction we should be headed. Given the prices of some fuses cost does seem to be an issue.
BruceD
1,516
587
540
DISCLAIMER​
Indeed!--I'd hate to count up the $$$'s down the gurgler with blown so called "audiophile fuses"
Tried Hi Fi Tuning, Synergistic Research , Furutech, AMR, --all at the correct for the PSU T rated --disintegrate upon turn -on:mad:
Reapplying the factory supplied fuse --same rating and configuration --Unit fires up no problem.
My conclusion is seemingly these "after market" products have no surge capability--or am I missing something here.
Anyway I've given up -with the cost of these little b**gg*rs through the roof--I'm relinquishing spending any more hard earned on them
Meh!
BruceD
Mikem53
662
581
105
DISCLAIMER​
LOL.. After reading your first post, I modified all my equipment and removed the fuses.. Now I have no music at all, is there a Lawyer in the house? , Anyone ?
Gregadd
1,790
1,850
Metro DC
;) Predictable results from taking advice you get off the internet.
Reactions: Mikem53
stehno
1,595
461
405
Salem, OR
What say you?
Not sure what a toroidal transformer has to do with your question. However, if your question is about performance potentials between a simple fuse and circuit breaker interal to the component, on its face, I'd opt for the internal circuit breaker.
But that's also not knowing much about the internals of internal circuit breaker, quality of materials, etc. nor with a fuse for that matter. Non-audio grade standard fuses are cheap $0.50 retail parts I think mostly of aluminum. I've had audio-grade $50 fuses and I've had $0.50 cent fuses both cryo-treated and non-cryo-treated.
My Class D monoblock amps each employ an internal circuit breaker as do I think each of my little dedicated line conditioners and I'm comforted knowing that this difference alone most likely contributes to their performance and it's potentially one less perforamnce bottleneck. So it's only my source and sub that use fuses.
Then again. From a performance perspective, a fuse say even the very best aftermarket fuse available is a very very simple design whereas an internal circuit breaker must be far more complex. IOW, the electrical current flow is most likely having to travel through more parts via an internal circuit breaker than a fuse so I suppose the internal circuit breaker by its more complex design alone could potentially induce more performance compromises. But I'm reaching. In the end, whichever way a designer goes, I think the simplicity of design, quality of construction and materials and whether or not the electrical object is or could be cryo-treated determines greatest performance potentials.
I'm pretty sure my amps' internal circuit breakers are not cryo-treated and if not, that should be a little compromise in performance. But the line conditioners' internal circuit breakers are cryo'ed.
I've also tried inserting for a short time a standard 8-gauge I think Home Depot copper solid core wire which happens to be roughly the same gauge as a standard fuse. I replaced a single audio-grade fuse with an 8-gauge copper wire blank cut to the same length as the fuse. As I recall, after a few days of burn-in, I thought I heard an ever so slight improvement but re-installed the audio-grade fuse as it was not worth the risk to what was then an $8500 amp. I'm all for performance at MOST any cost but risk mgmt from all perspectives much take precendence.
To my ears, just replacing a single fuse with an upgraded version, I generally cannot distinguish an audible difference. However, if I upgrade all my fuses say 4 or 5 at the same time, I can easily discern an audible difference AFTER burn-in. Just remember that even a tiny fuse will take roughly 2 1/2 days of round-the-clock burn-in / play time before hearing any difference.
As for modifying existing components to replace internal fuses with internal circuit breakers? Not a chance. Sure, there are a few who are able to do so while keeping a performance-oriented mindset e.g. soldering types, quality of circuit breakers, etc but there's also hacks and also-rans out there and I would not take such a risk as again risk mgmt must always come into play. I'd much rather purchase a new component where the designer already has accounted for such performance issues from the ground up.
stehno
1,595
461
405
Salem, OR
No lawyer required as no fuse and no music puts you into the safest of all categories. IOW, lawyers will hate you most of all.
