Schiit Yggdrasil or Holo May (and if May, how much does ZTE version get you) or ??? in the $5k range?
ACHiPo
519
309
310
Pleasanton, CA
As the title suggests, I'm looking for a new DAC in the <$5k range. I've read great things about the Yggdrasil for years, and the Holo May more recently. I think the Denafrips is in that price range as well (well, actually $6k).
My current DAC is a modified Gustard X20, and it sounds quite good to my ears. I'm just getting the itch to try something different.
Do I just order the May ZTE and be happy, or is it worth giving the others a shot?
Can someone point me to a comparison between the different levels of the Holo May, i.e. what does the extra couple $K buy in terms of performance?
enginerd
5
2
5
57
San Francisco
I'm assuming you meant KTE. The technical changes are listed on the Kitsune website of course, but I'm not aware of any listening comparison between the different versions (there aren't that many reviews of May DACs out there as it is). I went with KTE because at that point, I was in it for a penny, in it for $5k...
I came from a Yggy to a Spring KTE to the May KTE. The May compared to the Spring is much more neutral sounding and much more detailed. It's been too long since I've owned a Yggy so I can't give you direct comparisons there. You may have seen DAC comparisons on other sites where Yggy and Spring were comparable in performance.
You've probably already read the reviews of the Denafrips and the May in Stereophile.
Reactions: ACHiPo
Joe Whip
1,740
563
405
Wayne, PA
I am biased towards the Yggy. It has quite a back order btw. A friend had the Spring and an Yggy with a purpose built room. He sold the Spring. It had a rolled off too end. Neither he nor I liked it with his Evolution towers. Found it boring frankly. Best to see if you can audition stuff to see how it works with yourself and your room and your tastes.
Reactions: Mikem53 and Al M.
gestalt
191
219
130
Nashville, TN
gestalt.audio
Reactions: Historia
Tinear1
53
67
98
58
I would also look at the SW1X Dac-II-Balanced. I came down to it and the May-KTE coming from the PS Audio DirectStream. I did order the May but only because of the broader selection of inputs if that matters. The SW1X to me is like the Lampizator on steroids... wow but SPDIF in only.
Reactions: ACHiPo
Al M.
8,818
4,559
1,213
Greater Boston
One person's boring is another person's relaxing ;). Things indeed depend on personal taste. Yes, the Yggy is very exciting in its presentation of music, with lots of life, dynamics (both macro- and micro-) and rhythm. The amount of detail is just staggering, but it does not necessarily draw attention to itself, since it is presented in a natural, not hyped-up manner.
ACHiPo
519
309
310
Pleasanton, CA
Thanks! That’s a new one to me. I’ll check that out.
ACHiPo
519
309
310
Pleasanton, CA
Enginerd,
Yes the KTE. Your response makes me just want to pull the trigger on the KTE. I’ve read reviews on Yggy, Spring, and May. I saw Guttenberg’s review of the Denafrip—not yet sure of how much I trust his reviews. Herb Reichert, though, I trust, so I’m biased toward the May. I’ll have to look for Stereophile review on Denafrips.
What made you go from the Yggy to the Spring?
Thanks!
ACHiPo
519
309
310
Pleasanton, CA
Reactions: Historia
ACHiPo
519
309
310
Pleasanton, CA
After looking at the Lampizator and SW1X, I decided that I really don’t want to deal with tubes on a DAC. I read the Denafrips Stereophile review, and decided to order the Holo May KTE. I’ll post my notes, but only have the modded Gustard to compare it to.
”In for a penny, in for $5,228” (shipping does seem a little steep!)
ACHiPo
519
309
310
Pleasanton, CA
How long did it take to get your Holo May? The website claims it's in stock, but I've heard that the lead time can be several weeks.
ACHiPo
519
309
310
Pleasanton, CA
Just heard from Tim Connor. Expected delivery is in about 7 weeks.
Tinear1
53
67
98
58
I made my decision and ordered 2 weeks ago. I'm expecting 5-7 wks. In researching it looks like they are made to order and the "in stock" means the parts are at hand to get started building. The web site says 5 wks. but I heard that they got behind during the Chinese new year and it's closer to 7 wks. at present but I'll let you know when I receive mine.
Reactions: ACHiPo
ACHiPo
519
309
310
Pleasanton, CA
Tinear,
Congrats. Your post is almost what Tim wrote to me verbatim. Seems like we'll be on a similar path, with you having a 2 week headstart.
Best,
Evan
enginerd
5
2
5
57
San Francisco
Tinear,
Best,
Evan
"In Stock" just means they have the parts on hand. The units are pretty much built to order which is why it takes awhile even though it is "in stock."
We'll all be very interested in what your thoughts are once you receive it.
Reactions: ACHiPo
ACHiPo
519
309
310
Pleasanton, CA
I decided to hold off on getting the Intona since there's no savings in shipping (the DAC ships from Hong Kong, the Intona products ship from WA). I figure I'll try the DAC stock for a few weeks, then try it with my ISO Regen. If I hear any benefit I'll pull the trigger on the Intona, as the consensus seems to be that the Intona sounds better than the Regen (although I'm skeptical about both with a well-designed DAC).
16,250
13,725
2,665
ACHiPo
519
309
310
Pleasanton, CA
Well, so much for holding off. I should have my Intona and new Intona USB cables in a few days. My USB from the Aurender to the Gustard has gone from intermittent to not working. The coax and AES work fine between the Aurender and Gustard, so I'm thinking it's either a USB cable, or perhaps a flaky USB socket on either the Gustard or the Aurender.
Esotar
411
362
340
South Korea
www.digituslabs.kr
I tested two models for over 3 months each other.
I recommend May DAC.
No comparison.
Reactions: ACHiPo
ACHiPo
519
309
310
Pleasanton, CA
No comparison.
Esotar,
Which version of the May did you test/buy?
Thanks,
Evan
