During the last years I spent my time mostly with Belt Drive turntables, but whenever I had contact to a proper Direct Drive, I am fascinated.
Currently I do use the Micro Seiki DQX 1000 and the DDX 1500 direct drive , at my friends home I can listen to Technics SP10 MkII and the Brinkmann Bardo.
All of this Direct Drives have something in common, they play piano with brute force and crazy dynamics while having a very clear tone.
I am using the Japanese Three Blind Mice Jazz records to compare, as nearly everyone I am visiting has this records in his collection.
4 weeks ago I was invited to a shoot out, some actual turntables in the 20k region, some vintage turntables, belt drive and direct drive.
As all of the turntables have their own fan boy culture, I am not going to list them up. But important for me was, that I was familiar with the different turntables,
but not with my personal "winner" of the shoot out. The former reference product from Trio / Kenwood:
Kenwood L-07 D
The Kenwood played the different Three Blind Mice Jazz records in a way, that I had to listen to them again and again, finally I made to the owner an offer and
went home with the Kenwood L-07D in my car
At home I started the google research about this turntable. Nearly all and everything is documented on this page, which was very helpful :
I learned, that I have an early version of the turntable and that the optional accessory kit was missing.
Finally I found the matching
Kenwood DS 20
outer Ring (in the Netherlands) , and the related
Kenwood DS 21
platter weight (in Hongkong)
and finally the
Kenwood TS-10
Ceramic Platter sheet (in Germany).
Still missing is the centering tool to better place the outer ring, if used on top of a record.
Placing the L-07D was easy , as I still have the HRS M3x platform , originally designed for a Brinkmann balance, which fits the L-07D like designed for this turntable.
As the Kenwood list of accessories shows thick rubber feet to be placed underneath the turntable feet as well, I used the GRS Nimbus feet under the Kenwood original feet.
The 7 Kenwood engineers involved in the Kenwood 07 project did a lot of basic research to design this turntable, so the heavy plinth is made from different materials.
The tonearm
Kenwood TA-07 J
as such is similar complex, but easy to handle. VTA can be adjusted during playback.
The standard Platte sheet is from Stainless steel, the optional from Ceramic.
On vinyl Engine a link to the manual can be found, showing some measurements as well.
www.vinylengine.com
same for the outer ring
www.vinylengine.com
It is possible to use the steel and the Ceramic platter sheet as a composite, so I tried different set ups.
My current "best" looks like the following sandwich:
baseplatter, than ceramic platter. centered by the ceramic platte the outer ring is placed. On top of the ceramic platter comes the steel platter.
And the last add on is the thin brown Micro Seiki Leather topper , which I like on steel platters.
But maybe this set up will change, as the platter weight is not yet arrived and I am using a different weight.
To get a start on this vintage table, I am using the
Acoustical Systems Fideles
6mv output cartridge. The heavy Titanium body fits nicely into the over all Design of the Kenwood turntable, but finally I will fit a contemporary cartridge into the L-07D.
Now I am listening and enjoying music with the new member of my turntable collection
The first impression matches my listening experience at my friends home, now I understand better, why you can find reports from other shoot outs,
seeing the Kenwood L-07D far ahead over the Nakamichi TX 1000 , another nice example of Japanese engineering quality of this decades.
Looking about market pricing, the Kenwood L-07D had a factor of 5x in market price increase over the last 10 to 15 years (in Europe),
which is still a conservative curve compared with Micro Seiki RX 5000 or SX 8000 residual value development.
If you are looking for such a turntable, you should know, that in some markets the L-07D was sold as "Trio L-07D" and not as "Kenwood L-07D"
as example in the UK.
Kenwood L-07 D
Kenwood DS 20
Kenwood DS 21
and finally the
Kenwood TS-10
The tonearm
Kenwood TA-07 J
Kenwood TS-10 Ceramic Sheet Turntable Mat | Vinyl Engine
Kenwood DS-20 Disc stabiliser Vibration Suppressor | Vinyl Engine
