Everest - all in or only front-end?
pleroma
167
198
150
I'm wondering how many Everest owners, previously with amps in a separate dedicated circuit, have tried the amps in the Everest with the front-end? Caelin was generally not in favor of it, and is working on a Typhon V2 for this very purpose. In the meantime, from what I've heard, there are mixed opinions about putting everything through the Everest when multiple dedicated circuits are available. I'm curious about those who may have found one way or another.
dan31
1,018
367
1,653
SF Bay
Depends on the amp. All equipment on one line can keep the system tidy and tied to a single ground. I use 1 20 amp line for my system. Everything into a RSA conditioner except my Io phono, that goes to the open plug on the same outlet.
Reactions: Long Live Analog
pleroma
167
198
150
Depends on the amp.
Agree; that, and probably everything else!
The question came up in a lengthy video interview with Caelin Gabriel, in the context of those who had an additional dedicated circuit for their amps, but not necessarily the funds for another Everest. Caelin's response was that he "couldn't imagine why anyone would do that," the implication being that he thought the benefits of a dedicated line surpassed those of a single, shared Everest (we admire Caelin's candor). But as has been the case with Shunyata in the past, customers tinker, and find new configurations of these superlative products more to their liking. I've been informed there are a small majority of Everest owners who've gone all in on one Everest. I'm hoping they'll take a moment to comment ...
dan31
1,018
367
1,653
SF Bay
If you have a larger space and push your amps to achieve higher spl then a dedicated line will provide the instantaneous current that Shunyata believes is most important.
I listen in a small room. My stereo amp pulls over 200 watts just sitting , max draw is 1600 watts.I doubt I ever scratch the surface of what it can do so I have no problem especially with the RSA design. The Everest would be just fine with everything into it in my situation.
BlueFox
1,709
407
405
I have 3 dedicated 20 amp lines. Each amp has its own line, and the source gear is on the third line. I started with one dedicated line, then added a second line, and finally added a third line. The sound improved with each added line, and Shunyata gear is on each line. Signature has the details.
pleroma
167
198
150
After some experimentation moving amps from wall to Everest, I prefer amps in the Everest, at least for now (last caveat added after reading the DTCD tutorial in Caelin's thread above). I heard things I hadn't heard before. Something is up if you're willing to miss a meal to listen for a good while. One downside might be that some favorite redbook recordings didn't sound as good as I remembered in the wake of others now sounding much better. My situation is similar to dan31's. But so many variables, and with techincal information to the contrary, I'll likely be second-guessing myself.
DetroitVinylRob
274
318
280
Metropolitan Detroit area, MI
I'm not running an Everest, though I am running two Denali 6000S V2 units.
One handling the whole front end and the other handling the OTL mono block power amps and the individual DC power supplies to the voice-coil drivers of the horn loudspeakers. AND, my results have been simply stunning.
Micro and macro dynamics like nothing I have ever heard, textures on textures and layers on layers. The depth of stage has increased dramatically and the timbre of instruments and voices has become much more vivid and lifelike yet at the same time more effortless, truly incredible. I have utilized Shunyata Research cables, especially NR and XC mains cables before, having some very good improvements, but the (x)2 Denali have been a real game changer, one of the single biggest upgrades I've ever experienced. When the noise floor drops, the transparency really shines through.
I realize everyone's mileage may vary and audiophile hyperbole can get more than a bit ridiculous, but for me, my musical experience, and my kit, it has truly been remarkable. From my experience the amps sound better on it then off it.
DTCD is a very credible and critical aspect of what we do here.
Reactions: pleroma
Crashem
92
38
148
I agree with pretty much everything said about it being highly dependent on the individual situation even though Shunyata recommends running direct into the wall. The only thing I would add is whether using dedicated lines or 2 Denali's, you should be testing use of the CGS to any of the unattached equipment.
