What do you think of this video. And this is not directed to those who think every mobile phone video is trash, thanks. Please listen to the end for the brass and the woodwinds
Difficult to say , slightly better i suppose as it ads a bit more warm glow to the music .Did you notice any change of the amps after warming up?
I agree with this entirely ! The source is the most important part of the set. The speakers need to be in "accordance" with the room... but are also very important for the "creating" of the sound not so much for the detail.Besides the speakers its very important to have a good DAC / pre amp (you can get good sound with various power amps )
I think that is a good sign. The further back the sound stage is the less "speaker" you will hear. But it surprises me a bit as the CAT is a tube amp (i generally give it more credit beeing spaceous).The sound stage is further back then with the CAT amp
They say CH precision is the bomb in that regard .The power amp need to be able to drive the speakers without adding anything (almost an impossible task as high speed, high current and micro signals come together on a complex load). The preamp has a questionable task (unthankfull task) as most line level sources are no longer "line level".
That is true as we cannot change the "personality" of a device we tend to compensate with cables and gadgets (audio vodoo and shamanistic rituals)... instead of dealing with it !If you have that wrong you ll be swapping cables all your life
If you are interested we can try a lot of different amp concepts (OTL, Zotl, SET, PP you name it as i have all available to "play" with...I d wanna define the sound with a top pre , power amp is of lesser concern imv.
Sure , i m certainly interested .If you are interested we can try a lot of different amp concepts (OTL, Zotl, SET, PP you name it as i have all available to "play" with...
Transistor amps is not in my portfolio... ( i have a Threshold preamp as SS reference to show how "bad" SS amps are, i hope i am not offensive to Nelson Pass by saying this as he is a nice guy and is doing a lot for the DIY community).
Here in the NL we have many DYI'ers and that is a good thing...I remember also a DIY person in NL who designed a tube amplifier around a absolutely massive output tube .
Thank you for mentioning the cable type- I was going to ask...BTW the signal cables i use and advice is this:
LIYCY 4x0,14 grau, 0,14mm², LIYCY, shielded - elpro Elektronik
Very "neutral", can be used as balanced or unbalanced cable (cross selecting and 1 side shield connection).
Nice picture , but the one i was referring to was a much bigger design and was built by someone around rotterdam .My smalles tube power amp can deliver a whopping 2.5W @4Ohm (balanced inputs) and will change your view of any power amp. Direct heated pentodes (ultra linear) powered by a 12 adapter.
You will be surprised ! SRV will sound nice at night ....Thats not gonna work on my speakers though
OMG ! i think i have the PCB's in house somewhere.... i will chck it for you...
