Against Alnico?I should be able to do that exercise with a Lowther and Stamm and AER in due course
From a physics perspective , the magnetic field is the same. So, it could be the sag we have discussed or it could be subtle differences in the geometry of the field and where and how the force is applied if everything else is not exactly the same as the permanent magnet setup.Thanks Ralph. From a technical perspective, is there anything innate to the magnetic field of a field coil motor that makes it in anyway different to that of a permanent magnet?
Why do you think the field coils have such speed technically - is it something to do with handling the perturbations in the field as the voicecoil moves through it or something?
Against Alnico?
That's a lot of Nd!!as I´ve understood, there are different qualities of neodynium
often mentioned advantage of using neodynium is less weight
however my TAD TD-4003s still weigh a substantial 9,9kg
I guess the use of Nd magnets would also improve the point about airflow behind the driver as they are MUCH smaller than Ferrites or Alnico. Interestingly, the shape of the magnet in my Supravox drivers (Alnico) are taller and thinner than you see with Ferrite and they have shaped the field coil version exactly the same way (length and diameter look from photos identical).interesting headline!
My Line Magnetic Audio LM-755 speakers are field coils. Line Magnetic is offering the LM-755 (Western Electric driver Design) as Allnico, Solid-state powered Fieldcoil and Tube (300b) powered Fieldcoil. Unfortunately very rare speakers, so I had not chance so far to compare.
A couple of years I listened to music with a full Audio Note TT3 turntable, incl the I.O. Limited cartridge, which was field coils as well
(6 x single tonearm wires instead of 4)
During that time, I also had some discussions with Wolf von Langa and others (during a Munich Audio fair).
The obvious positive arguments about field coils were the magnetic field power as such and the position of the field.
But I learned two other arguments, one is, that the weight of a magnet is much higher than a second coil, which has a huge effect on resonances of the chassis body (even higher effect for a cartridge assembly ), the second argument was the improved / free airflow of the chassis membrane, as the back movement of the membrane does not have to work against the magnet body surface.
In this regard many chassis manufacturers are working on the improvement of the airflow and do create special magnet designs, so it seems, that this is an important criteria to be included in the field coil debate as well.
I’ve enjoyed John’s T1.5 speakers at several shows (matched with @Atmasphere’s amps.) I would really like to hear his reproduction Hartsfields with field coil drivers.Classic Audio Reproductions also has field coil drivers, based on ALTEC design I think.
John of Classic Audio Loudspeakers did a demo on this at T.H.E. Show years ago when it was at the St. Tropez. It was not subtle at all.I have not compared Field Coil against Alnico,
I've never seen an Altec that didn't use Alnico ( I've owned a bit of Altec stuff over the years). FWIW Alnico is the earliest PM material used. Ceramic magnets came along in the 1960s as best I can make out. KLH was an early advocate.Altec was pre Alnico
They sound quite nice but I prefer the horn on his Project (T-1 and T-3) speakers as it has smoother response. It is amazing though how much bass extension he's managed to get out of the Hartsfields!I would really like to hear his reproduction Hartsfields with field coil drivers.
When John of Classic Audio Loudspeakers was first working with FC stuff he was also working with pure beryllium diaphragms in his horns (the first breakup being about 35KHz). You hear either one and you don't want to go back. The beryllium drivers had a speed and smoothness not present in any of the drivers that didn't use it whether they were FC or not. But put the two together and you have something special.the material of the diaphragm affects the sound more than the magnetic drive.
The frequency is irrelevant. If the power supply is properly regulated it will work fine powering all the drivers, assuming that they all work at the same voltage. FWIW its the current you put through them that is important, although of course you can't get the current without the voltage.Do field coils do better at a given freq ? High or mids ?
also I heard a system of horns all field coils but they used the same psu for all 5 drivers
I would think this is a bad idea
This is incorrect. John started by reproducing the Hartsfield speakers which used JBL. His T-1 and T-3 speakers initially used TAD 1602s which employ Alnico. Later he modified JBL drivers to use FC operation. He's not messed with Altec much that I've ever seen. I've known him since 1990 if that helps.Classic Audio Reproductions also has field coil drivers, based on ALTEC design I think.
I can also confirm that John uses JBL for his FC operation. I spoke to him about Hartsfield reproductions a few months ago.John of Classic Audio Loudspeakers did a demo on this at T.H.E. Show years ago when it was at the St. Tropez. It was not subtle at all.
These comparisons are not easy. Altec was pre Alnico, and when the price of cobalt went up Altec started doing ferrite and for those who had both they say the ferrite sucked. However, GPA Altec Alnicos were then not considered as good as original Altec Alnicos. Some consider it better than the original Altec Ferrite,
TAD came out with Neodynium in 4003 to improve on their Alnico 4001, but that worked for them, not sure this can be generalized. It was the same engineer who had made the 4001 and previous JBL drivers. Either way both my tope favorites in 4003 and AER are neodynium.
I'm sure Bill and some others have already seen this content, but since this thread is a place to collect valuable information on field coil design:
https://www.facebook.com/ProjectRyu/ & https://projectryu.com/wp/ & https://www.diyaudio.com/forums/multi-way/212953-project-ryu-diy-field-coil-loudspeaker.html
