Multiple layers of marine ply...could be. As I have the Verdier I guess I'm just not interested enough in the Garrard to try to fix it with a different plinth.I wonder if that plywood plinth is overdamping the 401.
In your position, I think I would also live with the Verdier.Multiple layers of marine ply...could be. As I have the Verdier I guess I'm just not interested enough in the Garrard to try to fix it with a different plinth.
He built three of them!Jeff - very nice build congrats! I had less than great experience with my build in a high mass wood plinth. I think the key is maybe the alu top/bottom plates Peter installed. Great work by Peter as always. Maybe this project has him switch from dd to idler
Well the Verdier is one of the all time great tables from the end of the golden age of analog reproduction. Please post some pictures of that beauty!Multiple layers of marine ply...could be. As I have the Verdier I guess I'm just not interested enough in the Garrard to try to fix it with a different plinth.
I have added the Long Dog Audio Quartz Turntable Power Supply to my Garrard build and I have to say I'm very pleased. Using the RPM app on my iPhone (also highly recommended) my speed would vary between 32.5 and 33.9 while the platter was spinning. With the LDA engaged the platter is spinning EXACTLY at 33.3, its rock solid.
With the improved speed control the table sounds even better and more alive. I had several people over for father's day that are music lovers and they absolutely flipped over the sound of my system. They've heard it with the Ascona for many years and all said it sounded much closer to live music than ever before.
The LDA is highly recommended for anyone with an idler turntable.
LDA Quartz Turntable Power Supply MKII
The LDA Quartz Regenerator will allow you to get the best sound possible from your turntable. It’s that simple. The unit is supplied with a mains power lead to suit your country (UK-EU-AUS-USA) and a cable from the power supply to your chosen turntable. Available to suit voltage in any country...www.longdogaudio.com
I was extremely skeptical and really purchased it with the intent of trying it and returning it. It's not going back.Nice - was considering one myself for my Gates
doesnt seems like voltage adjustable . Is the magnetic brake is still engage ?I have added the Long Dog Audio Quartz Turntable Power Supply to my Garrard build and I have to say I'm very pleased. Using the RPM app on my iPhone (also highly recommended) my speed would vary between 32.5 and 33.9 while the platter was spinning. With the LDA engaged the platter is spinning EXACTLY at 33.3, its rock solid.
The voltage has just two settings: 50hz/220 volts and 60hz/120 volts. The speed break does still engage.doesnt seems like voltage adjustable . Is the magnetic brake is still engage ?
Which app are you using? I have an Allnic speednic but it doesn’t give numbersI have added the Long Dog Audio Quartz Turntable Power Supply to my Garrard build and I have to say I'm very pleased. Using the RPM app on my iPhone (also highly recommended) my speed would vary between 32.5 and 33.9 while the platter was spinning. With the LDA engaged the platter is spinning EXACTLY at 33.3, its rock solid.
It’s called RPM on the Apple App Store.Which app are you using? I have an Allnic speednic but it doesn’t give numbers
I use one myself on my modded Lenco, fantastic piece of kit for Idler drivesI have added the Long Dog Audio Quartz Turntable Power Supply to my Garrard build and I have to say I'm very pleased. Using the RPM app on my iPhone (also highly recommended) my speed would vary between 32.5 and 33.9 while the platter was spinning. With the LDA engaged the platter is spinning EXACTLY at 33.3, its rock solid.
They adjust frequency, that's why you still need the break to stop the table. There are various opinions regarding the eddy break. Some say it is better to remove it, some say that the break is part of the "magic" of the Garrard sound. I went with the LDA because it was more "set and forget" than the Hanze and it was also half the price.There’s two dials on the device. One says 33/45, the other speed adjustment.
Do they adjust voltage or frequency?
If so, why is the mechanical brake still needed?
Sorry not similar the HAT powersupply is a analog oscillator with very low distorsion and a poweramp delivering a stable output voltage and frequency.HAT, swissonor and schopper PSU were covered in my schopper write up a few years ago. All similar.
I have several other head shells by Audiotecnica, Yamamoto (wood and carbon fiber) and I own an Arche headhsell. All different sounding, although I really can’t really say one sounds better than the other.I do love the installation, the precise work, also the tonearms. But please do me a favor. Those SME headshells need a better substitution for really good sound!
best
E.
www.AudioCirc.com
