Ok. Interesting about the Mayer 46. I have not heard that amp but own a ~diy 46 and have heard Mayer 300b and would think his 46 to be a great match. Maybe the impedance curve is tough on the Pnoe?
Room sensitive because this design wasn’t made for indoor use!They are surprisingly room sensitive, as in they sound flat in corners and muffled. But the key when you have no cross over is to take advantage of the nuance it is capable of and the high dynamic range so all electronics have to suit. Nuance and agility should not be suppressed anywhere in the chain. It does not do well with poor source or recordings and the bass cam sometime go off time with high unless right amp is used. I never really heard it sound good with Mayer 46, and red sparrow and linear tracker and great records. And I have heard it with 6 amps plus Munich. I understand there is a possibility to hear with new electronics now that work wonders so at some point in the future hope to listen.
Never tested it. And I did not build it, was made by Sayes out of repurposed Tamura iron. Never said its on the Mayer level but it does a lot of nice things. I suppose its 1w...Interesting you have a DIY 46. How many watts is it
I picked it to go with my own diy 'akido meets silvercore' phono as it ( 5842 into 46 ) doesn't need a lot of gain and I wanted a phono-passive-amp arrangement for my slow build non commercial system
David, I've heard the Pnoes twice, tbh I told Ked at the time that I was left cold after such a big build up. Nice on piano £00s half century old lp.Let’s get serious here Ked those speakers are a plastic pipe with a driver stuck at one end, what setup?
david
