Thank for the link Ked, appreciate you remembering my interest !
We are the only two people on forum who have been to Malvern concert hall, and that too to watch the same concert. Difficult to forget
How should one sort through the myriad of variables between tables that contribute to SQ in order to isolate and conclusively determine that "stable accuracy" is the (or even "a") major contributing factor?Listening to music I believe our ears are more sensitive to rotational accuracy and stability than we might realize and in ways we may not expect. For example, I heard a difference between a table with 0,0007% (7ppm) peak error from 33? rpm and one with 0,0001% (1ppm) peak error from 33? rpm as improved dynamic control. I heard an orchestra sound what I'll describe as more organized during complex passages, as lower frequency rhythm sections held on to their tempos and volumes without muddle or looseness.
If you go looking for such differences between tables with different levels of stable accuracy you might not realize what you're hearing. For myself, in retrospect, it was a process of discovery - hearing sonic differences, improvements, then asking to what can I attribute these - ultimately there was only one explanation.
You are mixing accuracy and stability , your post is of little help to debate these parameters or correlate it with sound quality.
I recently recorded two videos that show both the speed accuracy and stability using two measuring devices... This speed stability results in a very solid, stable sound.... This may also be responsible for the superb and very subtle ambient information I am hearing.
I am now beginning to fully appreciate the reputation this fine turntable has earned and of which @ddk has written.
For DD it is very important the electronic control system and platter mass. Old concepts created "hunting" where the turntable was always changing speed in tiny increments of under and over correction. This would look fine on a normal tachometer but in fact is damaging to the sound...kind of an analog "jitter". By the late 70s to early 80s, JVC, Kenwood, Pioneer and others had developed more sophisticated control systems that also relied on mass (Kenwood L-07d had about 7kg platter and Yamaha GT-2000 a 6Kg one with option for 18KG one) to create smoother transitions with far less over and undershoot.Categorize them as far as what? Speed accuracy and stability? It all depends on the implementation. DC motors require compensation (current feedback) or there will be a negative torque/speed slope. AC synch motors have constant speed, but a belt driven platter does not because of belt creep, even if the motor is constant speed. All of the idler drives you listed use AC induction motors which are quasi-synchronous and will slow under load, but have tighter coupling between motor and platter (also potentially higher noise). Lenco made high mass and low mass platters. DD almost by definition should have high accuracy and stability. You can have very good performance with any of these drive methods or relatively poor performance, depending on how each drive system is implemented. I don't think you can just generalize about them.
As I posted previously, speed accuracy and stability are only one component that contributes to SQ. You also need to consider the drive implementation, plinth, tone arm, bearing, pulley accuracy, belt material and tension, damping and cartridge. And of course, you have to listen to the table which will be connected to which phono-pre, amp, speakers, room acoustics/treatments? Difficult to draw any useful conclusions without more specifics.
This was theorized, but was audible speed "hunting" ever proven or measured? A tachometer would not measure it but demodulating a 3150Hz tone from a test record might show this, depending on the amount frequency shift and the rate of shifting, by looking at the amplitude of the demodulated signal as well as the frequency spectrum (FFT). I don't know if "hunting" was ever proven, but if you have data on this, I would be interested.For DD it is very important the electronic control system and platter mass. Old concepts created "hunting" where the turntable was always changing speed in tiny increments of under and over correction. This would look fine on a normal tachometer but in fact is damaging to the sound...kind of an analog "jitter". By the late 70s to early 80s, JVC, Kenwood, Pioneer and others had developed more sophisticated control systems that also relied on mass (Kenwood L-07d had about 7kg platter and Yamaha GT-2000 a 6Kg one with option for 18KG one) to create smoother transitions with far less over and undershoot.
That's what I understood by your question, but I don't think you can make generalizations about any type of drive system because of the number of variables involved. I outlined what I see as some of those variables and the few generalizations that one can make, but I don't think you can draw any concrete conclusions without more specifics.When I meant categorize I meant the four quadrants shown by micro, which I know very well as it is kind of the cornerstone of analytical test method conception and I am an analytical chemist. We talk about accuracy (in this case as close as possible to 33.33333 or 45 rpm) and precision (how is it fluctuating from instant to instant and by how much?). It seems that the variability over short time periods is likely more damaging to tone reconstruction and timing than being off absolute speed a bit (obviously if this is off by a lot things will sound wrong...think a 33 record played at 45) but very stable from instant to instant. Variability over long time intervals also seems to be less damaging to the sound quality and this is what the later DD designs from Japan (think early 80s) seemed to aim for... along with some inertia thrown in for good measure to reduce the need for sharp corrective action of a servo.
It certainly sounds like confirmation bias could be a factor there. Wasn't it the case that they were not entirely forthcoming with respect to the full set of changes between the revisions?
Many reviews simply quote what the manufacturer tells them. I would like to know the measuring technique used.
Threshold of what?Since you are so keen on understanding what threshold is necessary, do any of these reviews
you cite discuss this?
Yes, several times. Using test records and SpectraPlus. I did not keep the spectra, the EMT 927 was the poorest measuring but sounded very good. In fairness I should say they my particular EMT measured exceptionally well for such turntable, significantly better than the manufacturer specifications.Did you ever measure your old SME 30, the EMT, or the TechDAS air force one? If so, what method did you use and what were the results?
(...) At the end we concluded that the majority difference should be a result of improved speed accuracy and speed stability first, and quiet operation second. Other minor changes were ruled out. So in part it was a process of elimination and a consideration of what was changed.
What led to the quieter operation? The new motor? A different bearing?Given two different tables from different manufacturers that is difficult to do by listening alone, if it is even possible. Different speed related specs might give some indication but there are numerous factors that can contribute to listening differences. In my case I had one version and its immediate successor to evaluate. The major difference between them was the motor and motor controller system.
I discussed the topic with the GPA engineers. They knew the differences in specs ahead of time, but were equally astonished with the sonic results, which were unexpected to the degree observed. We spent time talking about what could be the cause of the difference in sound. The new table was quieter with the cause of that attributed to the new motor and controller software. Alvin Lloyd claimed motor noise is impacted by how the motor is controlled. At the end we concluded that the majority difference should be a result of improved speed accuracy and speed stability first, and quiet operation second. Other minor changes were ruled out. So in part it was a process of elimination and a consideration of what was changed.
Data gathering. I've been interested in finding correlation between this level of speed precision and accuracy to SQ for quite some time. I still haven't seen any convincing data, but thanks for the anecdote.I don't understand what you are referring to.
I'm under an NDA but what little proprietary info I know does not change anything I described above.
Is there a point you want to make?
I disagree. Too simplistic.Brian, one way to start would be to measure a bunch of tables. If they all measure the same or within a very tight band that is both accurate and stable, then you can illuminate speed as a factor when assessing the differences between the various turntable designs.
in other words, if speed performance is very similar(pick the tolerances) then differences one hears must be a result of different factors.
Why do you insist on using the vague concept of speed stability, that GPA carefully avoid, wisely referring only to accuracy and peak or RMS variations? If we go through their site and papers we see they refer to stability as a mechanical or overall general concept, not as a speed epithet
Short of some sort of test bed where the parameters of interest (and only these) can be varied both systematically and randomly, I can't envision it. Too much has changed between 1.5 and 2.0 for sure, though. And IMO the only viable (marketing) justification for its MSRP and its entire point of differentiation is its extreme speed performance, so it'd be awfully inconvenient if that wasn't deemed largely responsible for its SQ.How would such correlation be expressed? What would convincing data look like to you?
1. Fair enough. The reviewers did their own testing or measuring of speed performance. You didn’t answer the question about what measuring technique they used. Nor within what toleranceNo, I am addressing the proper reviews by known reviewers.
Threshold of what?
