will the new TAS android app be in the google play store
Yes.
I’m using my Internet Service Provider router and a Paul Pang modified switch, while waiting for the Taiko new one come out.Quick question to All Extreme users
What is the router you use ?
I was comparing the ubiquiti edgerouter with edgerouter sfp and the one with sfp is a better sounding.
tried to look why is that and the only significant difference I could find was the 2 clocks in SFP version.
There is only one clock in regular edgerouter.
All proposals for ultimate Router are welcome.
what are you using currently with your Taiko Extreme?
I am also curious what Emile and Taiko Team is using.
I use #2Thanks to all ! More ifo form other users is welcome.
I think Router is a big part of the SQ.
This is also why we are getting different results.
Planning to test some of the solutions to make sure we know what is going on.
So far
1. Edgerouter X with pinkfaun ultra clock is a king
2. Edgeriuter X sfp
3. Edgerouter X
4. Cisco Linksys EA 4500
need more devices to try,
I remember Emile tested Nighthawk one time and it was a disaster.
But it looks Marcus has very good results with that.
I think Buffalo with PF clock , following NH is a big part of his success.
Not using a separate router at all, Kris. I'm going directly from one of the four provided RJ-45 ethernet sockets on the internet service provider's modem/router directly to the Extreme. I do however use a linear power supply instead of the ISP SMPS wall-wart for the modem/router.Quick question to All Extreme users
I do exactly the same. I don’t use any switches unless of course Emile releases one.Not using a separate router at all, Kris. I'm going directly from one of the four provided RJ-45 ethernet sockets on the internet service provider's modem/router directly to the Extreme. I do however use a linear power supply instead of the ISP SMPS wall-wart for the modem/router.
Steve Z
I am testing both options with and without Wifi....@Kris, if I had better network kung-fu I would have used the Ubiquity. I have the X with the SFP. I tried in vain to get it going on my copper network before fiber was added, and I could not get it to work correctly.
Now the only network traffic is if I stream Qobuz, or the WiFi commands from Taiko app. It's my "Extreme" vlan.
Are you still without a WiFi "attachment"? You were hardwired, as I recall.
I'm using a Nighthawk router with one band dedicated to my system. I believe I'm using a different model than the one Emile tested. I'm using S Boosters on both the router and modem.Not using a separate router at all, Kris. I'm going directly from one of the four provided RJ-45 ethernet sockets on the internet service provider's modem/router directly to the Extreme. I do however use a linear power supply instead of the ISP SMPS wall-wart for the modem/router.
Steve Z
I do exactly the sameI'm using a Nighthawk router with one band dedicated to my system. I believe I'm using a different model than the one Emile tested. I'm using S Boosters on both the router and modem.
Ubiquiti UniFi Dream Machine Pro
Processor Quad ARM Cortex-A57 Core at 1.7 GHz
16 GB eM Storage
4GB RAM that is DDR4 .
Most of what we use is single core, 512 mb ran ddr2 !
Not sure if Emile tried the most popular Edgerouter X SPF In comparison to his Dream Machine ?
Yes, the dream machine works better here, but there's more to it then just the device.
We had several connectivity issues with packet drops and sometimes poor throughput performance and/or high latency on wireless devices using a mixture of switches / wireless access points. Largely because this is a large building and we're using part of the neighbouring building now too totalling to about 2200 m2 to cover. The solution to this was using all Ubiquiti Unify devices and 3 Ubiquiti Unify Long Range access points. We now have a very well performing network, all devices have near 100% maximum throughput, low latency and no packet drops. Part of the ability to diagnose this effectively is centralised management as Unify provides when using all Unify devices. You can see where things go wrong and make adjustments. Surprisingly here now 5G wifi works better then 2.4G, 2.4G can even cause poor Roon remote performance, and that IS audible. In our previous facility in Hengelo I had a single Wifi Router running at 2.4G only and spaced it far away from the listening room. That does not work well here at all.
Right now there is NO difference here in SQ when unplugging the network cable after starting a track with TAS, while we have continuous network utilization, several internet radio devices streaming music all day etc. The obvious question here is IF in fact this continuous utilization is actually SQ positive, a constant "noise soup" where the deviation from using a wireless remote or streaming a music file is very small relative to the continuous normal utilization. To test this theory I have created a dedicated "music" VLAN, which, much to my surprise, sounded worse, with a sizeable uplift in SQ when unplugging the network cable. A logical next step would be to deliberately create a load while listening to music.
