Francisco, you can cut n paste all day long but that will not turn a non-balanced circuit into a balanced circuit. Given your conclusion above after reading reviews and Lamm's own specs, I'm sceptical of your understanding of what you read.
Tim,
I can't understand how you are now trying to move the discussion into nebulous waters to avoid the proper discussion around the M1.2R you and many others reviewed.
Let us be factual - we were debating ground problems and hum. These are typically due to input problems - noise induced at the input is amplified. I said the Lamm M1.2 is balanced surely meaning that it has real balanced inputs, making it much less susceptible to ground problems - you also have used it with balanced preamplifiers before.
The M1.2R has balanced input, as said by all other reviewers , Lamm specifications and the M1.2R manual I am reading - do you want me to post a scan?
Yes the M1.2 Ref has both RCA and XLR input connectors and one can take measurements based on which input connector is in use.
John Atkinson fully describes all the balanced parameters in his measurement section in 2003 review and later in the reappraisal in 2016. Do you think JA does not know what is a balanced input? Bascom H. King also posted an extremely complete description of the circuit of the similar balanced input M2.1 in his Audio May 1988 review.
However, If an amplifier has XLR connectors you cannot tell if it is balanced or not from those alone.
Yes, it is why must read and understand the specifications, something it seems you did not do.
The M1.2 has a balanced input.
Edit: Btw, your link is to an older version of the Lamm Web site, you might want to update.
Quite simply, the world’s best audio electronics Established 1993 Explore Products A legacy of audio excellence. Setting the standard for audiophiles the world over, LAMM Industries designs state-of-the-art audio products that deliver breakthrough performance with uncompromised sonic quality...
lammindustries.com
Thanks, there is no difference in the input specs between those pages.
Ralph Karsten was addressing Peter Lamm amplifier, the ML2 single ended, not the M1.2R hybrid. Just to end , even you acknowledged in your review that the M1.2Ref has balanced inputs:
(I am quoting your audiobeat review)
In the end, non-musical attributes may tip one’s considerations. The M1.2 is a solid-state unit with a single tube, while the Reference 250 uses eleven valves per monoblock. The Lamm amp is single-ended with balanced inputs; the Reference 250 is fully balanced. In summary, each of these amplifiers has its own strong sonic appeal, and I’d love to own them both., "
But you are mistaken - the M1.2 is not single-ended - it is an hybrid class A push pull, as you acknowledge in the review. BTW, fully balanced has a very specific meaning.
Just for curiosity, why do you think that we must insert shorting plugs in the non used RCA input when driving it with a single ended preamplfier? Hint - may be because it has a balanced input ...
