I have a 3-piece Aesthetix IO phono stage. I plan to use it as an MM stage loaded at 47k ohms. On the manual, it says, the 47k load setting is the factory configure. Is there anyone that can give me an idea of what it means by “factory configure”?
At the back the IO, there’re 2 separate jumpers which set the load impedance. I learnt (somewhere on this forum) that going without any jumper in place is the 47K, but not sure if it is the way to go?
Thanks in advance for anyone with experiences on setting the IO as a 47k MM stage.
