I'd echo this, but using the Flux "ultrasonic" cleaner. I currently use a brush each side, and once per week the Flux. Previously I used Onzow in place of the brush. Checking under a microscope, only the Flux consistently removes everything. The Onzow would leave little "lumps" of stuff over time and the brush often leaves/adds(!) little bits of crud. The Flux always leaves it sparkly clean. Like you, I am also a little paranoid about long-term issues with the machine, but so far no issues. I would say that I don't really hear any change in sound quality between brush and Flux, but I definitely did with Onzow and Flux - the Onzow cleaned stylus would start to sound dull after a while and the Flux restored the sound. With the brush I feel it's "good enough" and the Flux is just for certainty.I've tried them all and have done comparisons (checking with a 20x magnifier) and the only thing that was able to fully clean my stylus is the AT637 ultrasonic cleaner. I used just a brush, then just a brush with Audio Intelligent Stylus Fluid. Not much help. Then the Magic Eraser. Some more particles gone. Then the DS audio ST-50, still more but not "clean" by any measure. The AT637 got pretty much every trace of dirt/dust/gunk off my stylus. I've repeated this test many times and it's always the same. I assume the AT637 is safe but it does make me nervous but no issues in the 18 months I've used it.
That is very true. You can't overestimate how important it is to keep your records clean. When I had better access to ultrasonic vinyl cleaner my stylus required almost zero cleaning.My preferred approach is to keep my records clean, and then only use a brush on my stylus. Under magnification, the stylus looks good to me. And more importantly, it sounds like new.
I wish this were the case with me. Even with a Degritter in regular use, there is dirt on the stylus. I live near the ocean and it's windy and there's just no way to keep everything that spotless on a micro level.That is very true. You can't overestimate how important it is to keep your records clean. When I had better access to ultrasonic vinyl cleaner my stylus required almost zero cleaning.
For some time I lived near a highway. It was the same. Impossible to keep anything clean, but I would take the ocean over it any dayI wish this were the case with me. Even with a Degritter in regular use, there is dirt on the stylus. I live near the ocean and it's windy and there's just no way to keep everything that spotless on a micro level.
I also use a Degritter. My stylus looks pristine. I did start using Tergitol as recommended by @Neil.Antin recently, and I don't know if it'll make a difference. But the Degritter detergent followed by a rinse only clean-water cycle does. I doubt the ocean is depositing micro contaminants, but likely dust that you can see.I wish this were the case with me. Even with a Degritter in regular use, there is dirt on the stylus. I live near the ocean and it's windy and there's just no way to keep everything that spotless on a micro level.
Degritter here too. Dirt still accumulates on the stylus over time, but yes, at a very much slower pace.I also use a Degritter. My stylus looks pristine. I did start using Tergitol as recommended by @Neil.Antin recently, and I don't know if it'll make a difference. But the Degritter detergent followed by a rinse only clean-water cycle does. I doubt the ocean is depositing micro contaminants, but likely dust that you can see.
Hi nickif, Do you still like your Flux HiFi stylus cleaner ? Any disadvantages ?Just bought a FluxHifi ultrasonic stylus cleaner, this thing works like a dream!
