NoIs it too old school to clean the stylus just by gently sweeping the hard bristle brush from back to front? And occasionally a bit of Last Stylus Cleaner?
Does it have to be any more complicated than this?
It’s probably an easy task for experienced vinyl die hards like yourself, who have done it for many many yearsBut I am afraid to touch my stylus with a brush. It’s much easier to use the DS Audio cleaning pad.
I don't know about replacing a brush as it does the same job. It is safe to use.Do you think Flux ultrasonic stylus cleaner can replace a brush and is safe to use?
... When the Analog Planet Onzow report came out I took another look under the microscope and everything JR@Wallytools talks about is now all over my stylus too. Still, this is just an anecdote of course and Neil is correct to say we need to reserve judgment until we have the facts, but it will be very interesting to see how this plays out. Anyway, I did a non-Onzow clean (Flux "ultrasonic") on it to remove the crud and now the MAGIC is back. For now, my Onzow is off-limits leaving me with the urgent problem of gathering the tools for a new stylus cleaning regime.
This carried over from the tima's DIY RCM thread to here ...
It's good you got off the goop.
Imo the tools I use are simple and relatively cheap:
1) a size 00 soft artist brush with a little stiffness to it
Joe Miller Signature Series 50/50 Watercolor Brush - Round, Size 00
Our Joe Miller Signature Series 50/50 Watercolor Brush is an artist's dream come true. Half Kolinsky Sable and half Synthetic Nylon fiber, this watercolor brush points like a sable and springs back like a nylon brush.www.cheapjoes.com
Tim, it sounds like you prefer the soft artist brush to, let’s say, the Ortofon stylus brush?
Recently a friend’s EMT stylus is dropped off because of ultrasonic/vibration based cleaners. it’s not one hundred percent sure the culprit is the cleaner but I’m very skeptical about them.Do you think Flux ultrasonic stylus cleaner can replace a brush and is safe to use?
That sounds like a great brush, and good advice. The Ortofon / pad style brushes go right into the trash, here.Yes, I do prefer the soft artist brush. I have used similar to the Ortofon stylus brush (with the round head) but not for the last 5 years or so. I find it somewhat coarse, less effective and prefer not to drag it across the stylus.
The 00 artist brush mentioned at the link has a small amount of nylon bristles among the sable; that helps keep it stiff and pointed.
The trick for me is the 20X loupe - it yields a vivid clear image of the stylus and cantilever and will show dirt, dust, etc very well. Using that, I can pinpoint where the stylus needs cleaning then use the artist brush on that area while looking with the 5X hand magnifier. I will then re-check with the loupe. If there appears something firmly attached to the stylus the brush will not remove then I use the Magic Eraser which does an excellent job. There I just dip the ME onto the stylus using the hand magnifier, maybe 2-3 times. Then I will do a light touch with the brush. Moderately pains-taking, maybe a 2 minute ritual.
I find a clean stylus in a clean record stays cleaner and while I check with the loupe after each side, often no cleaning is needed.
I use both the DS Audio ST-50 and the Hifi Flux Sonic cleaner on my EMT JSD S 75, I have had zero issues.Recently a friend’s EMT stylus is dropped off because of ultrasonic/vibration based cleaners. it’s not one hundred percent sure the culprit is the cleaner but I’m very skeptical about them.
I use this to ,it’s a good styus cleanerLast 4 for cleaning with brush, last 5 to seal the surface of the diamond. I use it over 10 years no problems
Last Formula 4 Stylus Cleaner 7ml + Formula 5 Stylast 7ml | eBay
Entdecken Sie Last Formula 4 Stylus Cleaner 7ml + Formula 5 Stylast 7ml in der großen Auswahl bei eBay. Kostenlose Lieferung für viele Artikel!www.ebay.de
less dirt sticks to the diamonds and takes longer until the next cleaning. the playback noises are quieter maybe can also be imaginationWhat does "seal the surface of the diamond" mean?
That would be easy to test - just takes some recordings pre/post-cleaning and blind test using software such as Lacinato ABX.the playback noises are quieter maybe can also be imagination
it is Hifi Flux Sonic cleanerWhat ultrasonic cleaner is your friend using?
