Denali S correct phase.
plind
7
3
83
63
He llo,
I own a Denali S unit V1. There are no markings on the outlets(European) showing where the phase should be.
From pictures on internet I have seen markings on the lower side of the outlets. Is it important or not?
I guess the main issue is to get the phase correct on the gear being hooked to the Denali and that has been taking care of!
Alrainbow
3,260
1,431
450
He llo,
If it’s 230 volt both are phases
if it’s less like 125 then one is neutral and bonded somewhere
European power distrabution is in same ways not good for audio in regard to grounding.
Now an all 220 volt system I think also has benefits too.
Reactions: DetroitVinylRob
Alrainbow
3,260
1,431
450
Now if it is 230 a good practice would be to note the polarity of the two phases. it’s not a sure way to better sound but of all of your audio is set at the same phase markings it can’t hurt
Reactions: plind
plind
7
3
83
63
I turned the polarity around so the live end is at the bottom as shown in the pics I´ve seen.
As a result I had to turn all powercables attached as well. No significant change in sound so I guess it was not so important :)
Reactions: kennyb123
DetroitVinylRob
274
318
280
Metropolitan Detroit area, MI
He llo,
Have you seen that Shunyata has announced that all Denali v1’s can now be updated to v2 level?
plind
7
3
83
63
No,I did´nt know! Is it worth the extra Buck? What´s the difference between them?
DetroitVinylRob
274
318
280
Contact Shunyata: (an email was sent out)
Dear Shunyata Customers,
We are excited to announce the long-anticipated upgrade program for the original Hydra Denali 6000/T.
This upgrade converts existing Denali 6000/T units to version 2 and will include internal upgrades only (no external changes). Internally, the updated 6000/T v2 is an almost complete rebuild!
Denali 6000/T v2 Upgrade Features
• 6 independent zones of isolation (all 6 outlets are isolated from one another)
• 6 independent high current outlets
• Includes significantly improved versions of the QRBB, NIC and CCI modules
• Performance increase is comparable to or slightly above the award winning Hydra Denali 6000/S v2
UPGRADE COST: $1,500
If you are interested in upgrading your unit please contact Richard Rogers at richard@shunyata.com or call the Shunyata factory at 360-598-9935
Reactions: plind
plind
7
3
83
63
Thanx, but it`s the "S" version I own :) The description refers to the "T" version. Perhaps it applyes to both of them?
DetroitVinylRob
274
318
280
I imagine
