Looking to buy my firstTube Power Amp
Lowrider75
152
65
113
You don't need 100 tube watts for 89 db speakers unless you have a huge room. I run 89 db Bache Metro 001's (and 89 db Merlin VSM's before them) with a 35 watt Pathos TT and can shake the walls of my 16'x10' room if I want to. You have more good choices in your price range at lower power.
I don't believe the OP has said what speakers he owns. We know they are 89dB sens. but need to know the nominal impedance, better yet the impedance curve. You won't know how much power is needed to drive the speakers satisfactorily. Although 100wpc should be more than enough.
Cellcbern
1,224
733
585
71
Washington, DC
It would help to know the size of his listening room as well.
Cellcbern
1,224
733
585
71
Washington, DC
Note also that if I was in your position I would consider selling the Rogue preamp (I don't like Rogue components which seem to lack much of the "magic" that you buy tubes for in the first place) and getting a top tube integrated, which would reduce your box and cable count. Some of the firms I listed above also make integrated amps, and I would also look at Line Magnetic, Melody, PrimaLuna, and Unison.
jimbones
112
19
123
Since you liked it:
If you have a good tech upgrade key caps, resistors, connectors, and wiring.
Note that there are pre-owned tube power amps in your price range (and likely with enough power) for sale at Audiogon from Audio Research, Audio Hungary, BAT, EAR, McIntosh, VAC, and Zesto.
Is Audio Hungary any good?
jimbones
112
19
123
4 ohm speaker does not drop below 3.6 ohm. My drivers are Satori MW16P and Tw29R. I use GR Research H frame open Baffle subs with servo amps by Rythmik. My room is 14x22 with basement ceilings 7 foot plus
Lowrider75
152
65
113
Regarding the VTL, I found this on Stereophile...
VTL doesn't quote a rating into 8 ohms, since the VT-85 is optimized for a load of around 5 ohms, but Luke says that the 8 ohm rating would be around 70Wpc.
A very good match for your speakers. 85wpc into 4 ohms.
Lowrider75
152
65
113
I have not considered Rogue for power amp as some people say their tube amps sound more like SS (if thats possible) I can say that their RP7 is not like a typical tube Pre.
I would go with one of the power amps recommended and not a Rogue. The combo of Rogue pre and amp will have very good dynamics but will be more neutral and detailed than what it seems you're looking for.
jimbones
112
19
123
I agree with you 100%. I have narrowed it to Audio Hungary and Music Reference 200. Also if my buddy decides to sell his VTL I will take it off his hands.
Lowrider75
152
65
113
Music Reference is excellent. Audio Hungary... will it drive 4 ohm speakers ok?
Cellcbern
1,224
733
585
71
Washington, DC
FYI:
https://parttimeaudiophile.com/2020...00-vacuum-tube-stereo-power-amplifier-review/
jimbones
112
19
123
@Cellcbern Thank you for the links. I read the reviews but I dont trust pro reviews. Ive been burned before thinking "what were they listening to?" I prefer to see what owners of the product think. I find it more valuable. Maybe im wrong but.....
Brucemck2
428
103
1,598
Houston area
I’ve been very happy with various BAT amps. They’ve got great sonics, are highly reliable, and if purchased used are in your price range.
Reactions: Lowrider75
jimbones
112
19
123
I purchased CJ P12's with SED Winged C 6550's. Love it!!
LL21
14,430
2,518
1,448
Congrats! A legendary amp. I remember seeing the the CJ P12 and the Gryphon Antileon as the 2 amps on the website for Rockport Speakers years ago. Huge fan of CJ having owned a piece of CJ in the system for nearly 20 years consecutively...literally until only very very recently.
jimbones
112
19
123
I am using a RP& which some say is not in the same league as the CJ. I did try the RP9 and it was a step up. Not sure what model I would get if I bought a CJ Preamp.
