It connects the USB input on the back panel of the Medus to the integrated INT204 (which converts USB to AES/EBU).
That re-sends the AES/EBU to the Medus? Does the Medus get DSD through AES/EBU?
Yes. Yes however I believe it is converted to PCM first.
Oops.
Note, the conversion of DSD signals to PCM before doing the D/A Conversion has an advantage over a «native» DSD D/A
Converter in that the analog output filter after the PCM D/A stage is of lower order and hence sonically transparent
compared to the analog filter which is necessary in a «native» DSD D/A Converter.
Very interesting to read they may be thinking R-2-R...look forward to reading more.Weiss Medus is wonderful DAC , far better than many super expensive DACs.
I am not sure but It seems the Weiss Medus Discontinued and maybe It will replace by a New Weiss Reference DAC.
I am not sure but i guess the New Weiss DAC will be R-2R. If you have any information please share it.
Still my favorite DAC! The only DACs I’ve heard with a near analog level bass from CDs are from Weiss.
Weiss Medus has wonderful bassStill my favorite DAC! The only DACs I’ve heard with a near analog level bass from CDs are from Weiss.
david
It’s not only the extension but how natural sounding it is. Daniel is great to work with too.Medus has wonderful bass
Weiss has very Low jitter even at low frewuency,
The bass is Very extended
Hi Amir, are you hinting at something ...Weiss Medus is wonderful DAC , far better than many super expensive DACs.
