Thanks for keeping us apprised of your journey. Interesting stuff.Next up: to see if using the same approach with my APEX DAC and Upsampler will suggest these benefits in a similar way.
You’ve certainly a very fine system. Will be curious about what you “uncover” in using your Altaira. I would bet you’ll be somewhat surprised at the various places in your system where noise is overlaying and keeping quite a bit of detail from emerging. You’re about to embark on a new journey of “adventure” that I liken to “Alice in Wonderland” - puzzling and sometimes infuriating.My Altaira are arriving tomorrow. Curious to hear the differences, if any. I don’t have hum, “noise, harsh, or grunge”. One of the benefits of using top-notch gear, like my DarTZeel amps, is that there is no discernible noise and stuff… we’ll see!
There are no "powered components" nor cables, etc., carrying signal or power that do not have noise on them. If a device or component is part of an electrical circuit, it has noise. Even at the lowest "level" of any "electromagnetic" system, there will always be shot noise at the very least.My Altaira are arriving tomorrow. Curious to hear the differences, if any. I don’t have hum, “noise, harsh, or grunge”. One of the benefits of using top-notch gear, like my DarTZeel amps, is that there is no discernible noise and stuff… we’ll see!
Will be great to hear your experience. I also ordered two Altairas and it will be very interesting for me to see how the Taiko Extreme benefits from connecting it to a SG via its dedicated grounding post.My Altaira are arriving tomorrow. Curious to hear the differences, if any. I don’t have hum, “noise, harsh, or grunge”. One of the benefits of using top-notch gear, like my DarTZeel amps, is that there is no discernible noise and stuff… we’ll see!
Will do. It's arriving today. I may post in the Extreme discussion part of this forum.Will be great to hear your experience. I also ordered two Altairas and it will be very interesting for me to see how the Taiko Extreme benefits from connecting it to a SG via its dedicated grounding post.
Please share your results and water my mouth as my Altaira is probably a month or so away.
Happy listening!
If you do post there, please post a link here. Thanks!Will do. It's arriving today. I may post in the Extreme discussion part of this forum.
That's cool that Taiko has a dedicated grounding post. Wish more companies would do this.Will be great to hear your experience. I also ordered two Altairas and it will be very interesting for me to see how the Taiko Extreme benefits from connecting it to a SG via its dedicated grounding post.
Happy listening!
This is a great interview from Suncoast Audio interviewing Caelin Gabriel regarding the Altaira Grounding System.
My experience with Altaira has shown that each system is different. Each component within the system behaves in ways that may vary considerably in differing environments.My take away from this is I should be using the Altaira documents to work out the correct grounding method and test out star grounding items back to my Denali prior to committing to the Altaira - is this a fair take away and if so what cable should I be looking at to do this?
Thankyou
Hi, will do!Keep us up-to-date on your Altaira journey. I suspect you’ll find many unexpected results along the way. How was your dealer in-home analysis experience, which led to your specific purchases? Were you able to get all the components, analog as well as digital assigned through continuity testing, for dedicated chassis, chassis screws, or signal ground? Unlike your Taiko, for example, my Roon Nucleus offers no obvious means for grounding.
In that case, there are many on this forum who’ll be willing to share more about their own journey with Altaira. Undoubtedly you’ve already been encouraged to test one component at a time and give some time for a bit of settling in. I didn’t think this would matter but whatever “secret sauce” is in the Altaira must be reacting in some way over time to the ”noise” flowing into each terminal. And maybe in future, there will be additional guidance on measuring common ground potential in our systems, to identify alternative options to noise mitigation.Hi, will do!
I did not get a dealer in-home analysis - didn't want it. Honestly, my dealer would not know any more about this that I do, since it's so new. I communicated with Shunyata directly then purchased from a dealer.
I trust Shunyata's claims, and I know that if not satisfied, between them and my dealer, they will resolve the issue. I've never had to return any Shunyata products, but their customer service is outstanding. I believe they will not leave a customer in an unhappy state.
Yes, I was able to test continuity with each component: I only have 1 of 3 components that doesn't have a dedicated ground screw, which was the DarTZeel preamp power supply. I was able to ground that through a chassis screw.
Sorry, I don't follow. What do you mean?I didn’t think this would matter but whatever “secret sauce” is in the Altaira must be reacting in some way over time to the ”noise” flowing into each terminal.
The voltage that flows into each terminal of the Altaira makes its way through whatever material, what Ive I've labeled "secret sauce", to the primary output on the Altaira, and then to a grounding post on your Denali. Likely there is also some energy conversion: "heat dissipation" within, that occurs.Sorry, I don't follow. What do you mean?
