I’m a cookie monster - love ”swedish fika” all year around, and ”peppar-kaka” is always at my home.. -for the sake of hifi ofcourse, haha!Pepparkake-left overs from christmas Johan or are you eating pepparkakor all year round?
/ Jk
you are lying.
These are your comments the first two where you complimented him:
“Most of the other videos on WBF sound pretty bad and embarrassing,
I suppose you used real mikes for this recording, and not an iPhone?
And those videos almost always turn me off. Oh *that's* the sound you are enthusiastically talking about? Yeah, well...there goes the hyperbole, indeed. It's like the air is let out of the balloon.”
You had no interest in complimenting his system
/ Jk
Come by any time for a coffee - and I make sure to have a ”smörgåsbord” of cookies for you, haha.Pepparkake-left overs from christmas Johan or are you eating pepparkakor all year round?
Quite likely manufactured at the Mullard factory Mitcham Surrey ergo MM !?!?
Thank you for this report. Why, in detail please, did you prefer the Mullards?
THE GREAT MULLARD MAGIC BLOG
MULLARD MAGIC MULLARD TUBES MULLARD VALVES VINTAGE RADIO MILITARY RADIO LEAK QUAD RADFORD U52 GZ34 KT66 PX4 WS19 MCR1 SPY SET R1155mullard.org
A detailed but more robust sound, something I appreciate. BTW, Marty wrote excellent posts on the VTL 7.5 mk3 some years ago.
I just installed Marty's generously donated matched pair of Telefunken 12AU7s in the VTL pre-amp!
I am a tube swapper now!
But now that there are Telefunkens in the pre-amp as well as the amps, maybe that is too much of a high-definition sound? Maybe I should swap out the Telefunken ECC 801Ss in the inputs of the amps for Mullard 12AT7s to "balance" the Telefunkens?
Supposedly higher standard 12AT7 types. If the tubes 'flash' on startup, they are likely Mullards, but not all Mullards do this (the flash is harmless and a feature, not a defect).I see that these tubes are printed with "6201." Isn't that a USA manufacturer designation?
There are also 'Japanese Mullards' that also flash. These are nice tubes, sometimes labeled as Mitsubishi. The Japanese received the exact machining for Mullards from England and in their usual meticulous way built nearly identical products.
None, until your nervosa settles in again and your crave something different just to be different. I do that all the time. Telefunkens in spite of the elitist reputation do have a tendency to be a bit more on the possibly spare definition than the tonal volumetric side.If my Telefunkens are high definition without brightness or harshness, what would be the audio system equation in which people would use Mullards?
That's what I would try: Mullards in the preamp and leave the Tele's in the amp, but that depends on what you like better, of course, which nobody can predict. Ribbons will likely mellow out a bit more and might change your perceptions.So, in a situation like this, does it make sense to relatively randomly "split the baby" and to mix and match? Telefunkens in either the preamplifier or the amplifier, and Mullards in the other one?
You could help resolve this issue by borrowing somebody's reasonably transportable SET amp, not even of highest quality. You could even try putting the push pull on one channel and the SET on the other and volume equalizing, and see how the imaging changes as you go side to side. SET's I would hazard will never sound exactly like push pull of any pedigree.Phil last night, like Don a week ago, hears with the Pendragons an SET-style sonic benefit of triode mode which neither of them heard on the Magnepans.
I think Lamm ML3 would probably put you somewhere in a heaven on the ribbons that would make you not care any more about the technical niggles. That would already be somewhere pushing 100 db on the ribbons alone by RMS, much less transient response. The wild card is how well they perform in your volumetric space.
I do get that Ked, we see the value of videos representing the spirit and context of sound very differently to Al…Sonic preference is very different from making the same arguments against videos for last 4 years
