Thanks for the info. REL is certainly on the short list. The dealer from whom I purchased the A5's also recommended REL but they suggested a pair of Carbon Specials.My local dealer has a single Rel No.31 with his A5. Sounds very nice.
I'm sure a pair of Carbon Specials would be quite impressive. Honestly I don't think you are going to make a bad decision whatever way you go.Thanks for the info. REL is certainly on the short list. The dealer from whom I purchased the A5's also recommended REL but they suggested a pair of Carbon Specials.
I use homemade subs w 12” Peerless drivers and 250w cheap plate amps.I have a pair of Magico A5 speakers and considering adding a pair of subs. What subs did you use in your rig?
I use a pair of the SB4000s with my Wilson WP8s and they work great IMO.I use homemade subs w 12” Peerless drivers and 250w cheap plate amps.
Definitely a small improvement as subs tend to be, but nothing amazing.
I am waiting for SVS SB4000s to go on special and I will get a pair of them, UNported to match the A5s.
I am not sure I have ever heard a system as good as mine, but that is at dealers, I haven’t seen many audiophiles’s systems …
Nice you had a chance to compare both. My dealer has both, although he pointed me to the A5’s. Yes, he mentioned M2 were better, but to him, not so much as maybe what you heard. He is a dealer and has access to some crazy high end gear which allows him to hear across all sorts of gear, cables etc. A5’s hit a big sweet spot as noted by many reviewers.Heard a5 and m2 side by side. For me, I turned off the a5 and never went back to them.
Picked up a new pair A5's and was curious if anyone bought the A Pods ? Thoughts
I have my A5s on a "home-made" set of A-Pods (aluminium/copper/absorbent sandwiches)- seemed to improve things a bit- I would suspect that the A-pods would be a good additionPicked up a new pair A5's and was curious if anyone bought the A Pods ? Thoughts
Yes, and they only get better!I'm shocked with the sound of these A5's and they are not even broke in yet . OMG the bass ! Just a joy to listen to
I have IsoAcoustics Gaia Titan Theis 70 & IsoAcoustics Gaia Titan Carpet under my...FWIW @rau I have my A5s on IsoAcoustic Gaias. I used the stock spikes initially, but for me the Gaias are much better. Engineered wood flooring over concrete pad. Quite like the speakers, BTW.
Only wish I bought before the big price increaseYes, and they only get better!
