There is a Vitavox S2 compression driver in between the bass and the tweeter.Do you happen to know the approximate xover point of the main woofer bin (not the subwoofer) to the TAD 2002 in the VOX OLYMPIAN?
I have heard Perahia play 3, 4, 5 live across a couple of concerts.
How do you recommend getting good quality recordings of his playback on analog?
You say Peter believes neither his Vitavox nor David's Bionar system roll off treble frequencies. You say Peter believes that some modern systems emphasize treble frequencies. You imply that one of those beliefs needs to be false for the other to be true. Really ? I see no contradiction in holding both beliefs. Why do you believe they need to be reconciled?
So your reference becomes a measurement?
What do you hear in the concert hall?
The notion that there is an objective frequency response against which listening is assessed and gauged correct or not is a dire turn of direction that ultimately leads to grading/gauging peoples hearing. Is that where you want to go?
Thanks, I had the wrong driver name in mind, I indeed meant the large Mid Range horn.....There is a Vitavox S2 compression driver in between the bass and the tweeter.
Ron, why do you attribute this sense of realism to the Bionors? You were listening to a whole system. I have spoken to David at length about what is responsible for what. He attributes much of what you describe to his superior power delivery, the Neumann cartridge, and his AS2000 design. When I changed my power, from grounding to in wall wires to outlets and power cords, I heard a massive improvement in the weight, impact and fullness of the upper bass to lower midrange presentation.
I can't dispute what you say you heard and I cannot dispute your quantification. I can say that it sounds hyperbolic and that it does not make sense to me that switching from JPS in-wall cable to regular copper and switching from fancy power cords to Ching Chengs results in a "massive improvement in the weight, impact and fullness of the upper bass to lower midrange presentation." It's entirely possible that we apply a significantly different quantification to the word "massive."
Have you heard the Bionor‘s without the subwoofers?
RonI should remind y'all that with the woofer level control I can bring down the entire 20 Hz to 100 Hz range to make it more level with the adjacent 100Hz to 300Hz section of the frequency response curve. But as long as I don't hear the bass bump, and as long as there is no blurring of low frequency detail or texture, I am happy with a little extra measured oomph below 100Hz. I'll be curious to learn if I actually hear that extra oomph at the current woofer level setting now that the bass nodes are being addressed.
I will play with the woofer level control as time goes on.
Yeah, nothing wrong with a little "junk in the trunk." It is ok as long as you know what's going on.I should remind y'all that with the woofer level control I can bring down the entire 20 Hz to 100 Hz range to make it more level with the adjacent 100Hz to 300Hz section of the frequency response curve. But as long as I don't hear the bass bump, and as long as there is no blurring of low frequency detail or texture, I am happy with a little extra measured oomph below 100Hz. I'll be curious to learn if I actually hear that extra oomph at the current woofer level setting now that the bass nodes are being addressed.
Ron
Did Jason use a measuring device .. I woud be interested to see how it correlated with Ipad.
It looks like you have smoothed it out right through the range .. thats great !
Does it sound sightly less reverbarent now ?
Cheers
Phi
