If any designer bridges the gulf between love of music and audiophilia it is Vladimir Lamm.
+1
Good questions. I'm not Peter but I have long time tube experience. There are periods of time when my tub electronics are turned on 24/7 -- sometimes that is 3-4 days, it can also be 3-4 weeks. Your electricity bill will go up.
The more difficult time for a tube is when it is changing state -- when it goes from cold to fully operational and vice versa. Warm up time depends on the tube and circuit. Lamm recommends a minimum 45 minute warm-up. If cold, I will give the system 90 minutes warm-up before critical listening.
Imo, keeping tube gear on is not hard on the tubes. It is how they are meant to be used. Many tubes can last for years at their operating temperatures. However performance will drop over time for certain tubes. In the ML2/2.2 amps Peter and I use there is a pair of tubes (6NCP output driver) in each monoblock that Lamm suggests changing out once every year or two years, depending on whose documentation you read. The large more expensive 6C33C tubes will last 2-3 years of constant operation assuming plate voltages are properly maintained; best to keep those a bit under maximum. The large GM-70 tubes in the ML3 amps have a recommended 1-1½ year change out period.
Nonetheless heat is the enemy of any electronic gear. It is important to keep tubes clean. Handling them with your bare hands can transfer skin oils and dirt onto the glass. If the glass gets dirty, heat dissipation goes down and internal temperature goes up. Wipe them off with a cloth lightly dampened in alcohol and hold them with a cloth when inserting or removing. Wait for a fully dry surface before turn-on.
Decent ventilation in-rack is very important. Lamm front-end components are ~5½ inches tall. I suggest at least that much room above the component in a rack. On my SRA Scuttle racks there is ~10 inches above the component to the bottom of the shelf above. Optimally racks/shelves should be open front and back. It is not unheard for people to use small fans in tight racks when not listening. I will not put amplifiers in racks.
Given the variable availability of present day manufactury I suggest having two complete replacement tube sets for each component. Perhaps expensive but worthwhile peace of mind and you'll be thankful when/if a tube is no longer available. Russia cut off tube export when the Ukrainian conflict began. Among others, the popular Svetlana 6550C used in ARC power supplies and other gear remains out-of-stock at most US tube dealers.
I turn mine off because it takes about 30-40 minutes to sound about how it will sound and the rest is just wasting power and tube life. Also, I don't listen everyday, so why leave it on heating up the room?Thank you for such a detailed explanation!
I had always assumed that everyone turned off tube gear when not in use.
My gear is SS and it has been a while since I ran tubed equipment.
Tim is correct. This is a fact. The cycling process is aging to tubes.The more difficult time for a tube is when it is changing state -- when it goes from cold to fully operational and vice versa.
Tim is correct. This is a fact.Imo, keeping tube gear on is not hard on the tubes. It is how they are meant to be used. Many tubes can last for years at their operating temperatures.
Tim is correct. This is a fact.Nonetheless heat is the enemy of any electronic gear.
(...) If any designer bridges the gulf between love of music and audiophilia it is Vladimir Lamm.
Audio Note UK Peter Qvortrup recommends to leave on forever. His system is on forever.Same here. I have never heard from any other manufacturer of tube gear that you should leave it on. Never. Claiming that you should is the weirdest thing. Also, I don't want to set my house on fire.
(...) All Lamm gear is powered on 24/7. (...)
This being the prescient point … Leaving 6C33C’s running 24/7 is not necessary and pretty stupid imho!How to weigh these facts is subjective. If I listened to my system every day or almost every day I would keep on all components (except the giant power amps).
Most of the true stories about the benefits of keeping equipment permanently on are due to the presence and failure modes of electrolytic capacitors at startup.
Yup , Utter nonsense , In theory with 10000 hr 9 pin valves and again in theory large transmitting valves then yes , In practice and practicality simply Not necessary, If one must … fire the system up in the morning then power off when retiring.
Peter … For my part I very much enjoyed reading your initial impressions of the new Lamm phono electronics, you convey those impressions very well , I tend toward being a proponent of a singular manufacturer system synergy myself , and in that particular, I cannot envisage that you could have chosen a better phono amplifier with which to synergise with the rest of your system . It’s just that I tend not to promote my particular choice quite so pressingly .I appreciate that you are reading my system thread. What do you think of the essay about my listening impressions of the new phono stage?
Peter … For my part I very much enjoyed reading your initial impressions of your new Lamm phono electronics , I tend toward being a proponent of a singular manufacturer system synergy myself , and in that particular, I cannot envisage that you could have chosen a better phono amplifier with which to synergise with the rest of your system . Its just that I tend not to promote my choice quite so much.
No need for religious arguments here.
