Parry and thrust! It is going to take me a while to get this image out of my mind.Squirting most of an entire symphony orchestra out of one small-ish driver ...
I think people are missing out on a great opportunity here. Some intrepid and generous Wilson owner needs to host a shootout with an O/96 owner in the spirit of audio camaraderie and in the interest of audio science, or at least in the interest of audio entertainment. It would be the Battle of the Boxes. David vs. Goliath. Who wouldn’t want to buy a ticket to see that?!
Matt
Matt
In the last 6-7 years I’ve been moving and trying to get the best from my speakers. I use my living room with lot of glasses laterally. I was never satisfied. Tried many absorbers empirically.
Then I decided two things: sell the speakers and build a new listening room with top acoustician designer.
First thing he said: you never listened to what your speaker can do. Keep them until you have your listening room.
so I did.
many comments and conclusions we read here maybe are useless until the listening room is really good.
i think everyone who has an expensive set up has the ability to buy just for kicks an used O96 and NAF 2a3 integrated and play for a few days, then sell back used if they don’t like it. The fact that they won’t do it because “seriously dude I have 100k speakers and 100k amps, like big you know and you expect me to indulge in this foolery” is what stops them
An often neglected point. Broad frequency midrange drivers need some square inches to deliver. Most box speakers, the midrange is just too small. Larger surface areas allow transient intensity without having the diaphragm excursions move far. Many think this is applicable to woofers alone, but I think many box speakers starve their midrange square inches.Recall that I have my thing about driver surface area as an independent variable,
No, look at the data...they are certainly not. Ad claims can't hide the data.
A non-phase coherent speaker CANNOT be time coherent...period. The only exception is if DSP is used to digitally time align the outputs.
I like the three P'sIf you look at an impulse coming from a properly setup Alexia V or higher, The drivers are perfectly lined up to deliver that impulse to arrive at the listener’s ear at precisely the right time. Very few loudspeakers do this as well as Wilson due to their nomograph technology based on the ability of the drivers to move back and forth and up and down. When timing is correct, instruments are reproduced properly in terms from the mic doing the recording. So soundstaging is very precise.
Wrong, wrong, wrong. Go learn a bit of physics ok and then come back and try to discuss intelligently.This is simply not true. If you look at an impulse coming from a properly setup Alexia V or higher, The drivers are perfectly lined up to deliver that impulse to arrive at the listener’s ear at precisely the right time. Very few loudspeakers do this as well as Wilson due to their nomograph technology based on the ability of the drivers to move back and forth and up and down. When timing is correct, instruments are reproduced properly in terms from the mic doing the recording. So soundstaging is very precise. You now have precise spatial cues.
In other words, an impulse leaving from tweeter, mid, and woofer to arrive in perfect alignment must involve the adjustable drivers like Wilson uniquely does although some speakers do a partial job of it.
As for phase and frequency response, separate neural pathways control path in terms of a listener’s perception. It’s very hard to hear and process phase information. It’s different for timing. I believe the timing element is there due to inherent safety reasons, ala fight or flight.
A non-phase coherent speaker can be time coherent if the drivers are physically time-aligned.Wrong, wrong, wrong. Go learn a bit of physics ok and then come back and try to discuss intelligently.
No because of the group delay caused by crossover...only 1st order crossovers allow true time alignment passively.A non-phase coherent speaker can be time coherent if the drivers are physically time-aligned.
Right, you need a high order crossover filters to cancel group delay. You are technically correct that it won't be absolute zero without DSP. But I don't think the poster you're chastising is so egregiously incorrect as to deserve a flogging.No because of the group delay caused by crossover...only 1st order crossovers allow true time alignment passively.
Ummm...high order filters introduce even more group delay. This is why a 4th order Linkwitz-Riley filter, although phase coherent, will not work for time-alignment as the 360 degree phase rotation introduces a lot of group delay. The driver offset needed to get the time alignment would be quite large and not practical with box speaker. It doesn't look like wilson is using such a filter because A) the sloes aren't that steep in the frequency response plot in Stereophile and B) you would not invert the midrange with a 4th order design.Right, you need a high order crossover filters to cancel group delay. You are technically correct that it won't be absolute zero without DSP. But I don't think the poster you're chastising is so egregiously incorrect as to deserve a flogging.
Look at the review from Stereophile. Figure 2 shows the crossover rolloffs. These are clearly steeper than 1st order. Wilson Audio Specialties Alexia V loudspeaker Measurements | Stereophile.com
Then the impulse response in Figure 5 should look like a right triangle but it doesn't because the midrange is going negative when the other drivers are positive. So the tweeter and woofers go out when the mid is going backwards. Compare this with a truly time coherent speaker, the Thiel CS3.6
Thiel CS3.6 loudspeaker Measurements | Stereophile.com . In particular, note Figures 2 and 4 (taken at the right microphone height). Figure 4 is a proper right triangle and what a truly phase/time coherent speaker delivers. Do you see the difference??
Thiel and Vandersteen make phase/time coherent speakers because they used first order crossover and staggered/sloped baffles to align acoustic centers. Aligning acoustic centers without getting the crossover right will not lead to time alignment.
