I’ve been going back and forth between a F2a/Sophia Aqua 274b and a Bendix 6384/Cossor staggered plate 53KU combo. Now switching it up and listening to Bendix and Sophia. No final conclusions yet. I’m surprised how close all of these combos are.
Dont tell the old '50s Mullard GZ34s that.since rectis go much faster than the other tubes.
I’m ordering an A3 TRP with a few cherry picked options from the Golden Atlantic build. Rob got pricing from Poland for me.
The upgraded WBT sockets and upgraded premium capacitors for the power supply are 100 euros for each mod - so $200 euros for a good portion of the GA performance (I’m hoping). I didn’t want the copper chassis (already had that on my B3 that I’m upgrading from), I’ll upgrade my own tubes, and I’ve got isolation pucks already. Those appear to be the remaining GA upgrades, although perhaps there are others not listed. Either way, that’s hitting the important things from the GA build for me.
Mine will also have VC and be balanced, the large blue LED screen, and I’m doing the whole chassis in the Sahara Silver color. Should come out like the pic below.
I’ll post again when it arrives.
That looks like an interesting combination between the Bendix and Sophia. Looking forward to hearing how that works out for you!I’ve been going back and forth between a F2a/Sophia Aqua 274b and a Bendix h384/Cossor staggered plate 53KU combo. Now switching it up and listening to Bendix and Sophia. No final conclusions yet. I’m surprised how close all of these combos are.
Thanks for that, @jonstine, I just added the power supply caps to my recently ordered all silver single ended TRP. Really looking forward! I have three isolation footers on hand to try out, too. Isoacoustics Orea, Ingress roller blocks and Townshend isopods. Should be a lot of fun!
The Townsends arrived and are awesome under my AMR - I imagine they'll do the same under the Lampi when it gets here. Those Graphite Audio are beautiful and likely just a helpful as nicely crafted, but a little pricey for me....hooboy.Of the three footers, Townshend probably has the best reputation. One other that you might check out are the Graphite Audio Premium Isolation Cones, which is what Lukasz recommended for Horizon owners. I've used them under a TRP and now GG3, and they are the best I've had. Rob's company imports them and might give you a good deal.
I’ll piggyback off your question if that’s ok!Here's a newbie question: Do the 'power tubes' need to be closely matched as you would preamp tubes or are they 'auto-biased' in some fashion like power tubes might be? I recently received a single NOS Philips EL51 (thanks to a member here!) and found another, but matching is a little tough to get/find/get done...
I’m interested in this answer as well, but from the perspective of a Balanced A3. How closely matched does a quad of power tubes need to be in Balanced operation?
And forgive my ignorance, but if I’m not currently used the Balanced output, am I able to use the A3 single ended outputs with only 2 power tubes (1 pair removed)? I assume the answer is “no, all tubes must be present”, but wanted to check.
Thanks!
Always better of course! It's seems it may be less impactful using such incremental pieces of the fully available juice with tube in the A3 and up. ....the empirical method is easy enough. I only have two Philip EL51's to try, so it will have to be with some other set. Really looking forward to the A3 getting here and broken in so the gams can begin!I think the answer is yes to the single ended question. Easy to experiment and find out.
Do a search for “what if dac power tubes not matched?”
I’m still in the process of putting in work and reading through this ENTIRE thread when time permits. Currently on Page 64 after starting over from the original Page 100 I jumped in on. What a fantastic thread so far, btw!!Here's a newbie question: Do the 'power tubes' need to be closely matched as you would preamp tubes or are they 'auto-biased' in some fashion like power tubes might be? I recently received a single NOS Philips EL51 (thanks to a member here!) and found another, but matching is a little tough to get/find/get done...
I am reminded of the scene in the movie theater lobby with Marshall McLuhan in Annie Hall.I’m still in the process of putting in work and reading through this ENTIRE thread when time permits. Currently on Page 64 after starting over from the original Page 100 I jumped in on. What a fantastic thread so far, btw!!
It seems both of our questions were answered by Lukasz himself on Page 64, Post #1277. I’ve copied here for reference, with the original post made by @JonathanKlein:
@wison Thanks for the info. The following is confirmation from Lukasz with some additional details.
- Is the GA TRP 2 auto-biasing so that it will adjust for different spec tubes? In other words, as long as I insert a tube with matching pinout, it won’t cause damage to the DAC? YES, EXACTLY. ANY PENTODE OR TERODE WITH SAME PINOUT WILL WORK JUST FINE
- How important is to use matching quad tubes vs two sets of matched pairs vs all unmatched? Is there a specific left vs right side that I should install them if they aren’t matched? EACH TUBE HAS THE PARAMETERS SET INDIVIDUALLY, SO THEORETICALLY THERE IS NOTHING WRONG WITH USING 4 RADICALLY DIFFERENT TUBES. THE LEFT - RIGHT WORK AS “SEEN” AND REAR ROW IS BALANCED NEGATIVE, FRONT ROW IS SE AND XLR POSITIVE. WHEN YOU LISTEN TO SE YOU CAN USE ONLY FRONT ROW OF TUBES.
Based on your recommendation (and others) I just purchased a pair of NOS Siemens F2A tubes/adapters as well as a NOS Tungsram PV200/600 w/ adapter. Should all arrive by end of August or early Sept.I am reminded of the scene in the movie theater lobby with Marshall McLuhan in Annie Hall.
My A3 Balanced won’t be here until late Aug also, and I’ll let it burn in on whatever tubes are shipped with it. But I’m REALLY looking forward to trying the Siemens/Tungsram combo! Thanks for documenting your journey, it saved me and hopefully others a lot of $$$ and time.
Edit: I also have a new Sophia Aqua II 274B rectifier to try in the A3. I haven’t seen any other mentions of it’s sound character in a Lampizator yet, so I’m interested in checking it out as well.
I would also try every tube you have on hand anywaysBased on your recommendation (and others) I just purchased a pair of NOS Siemens F2A tubes/adapters as well as a NOS Tungsram PV200/600 w/ adapter. Should all arrive by end of August or early Sept.
I was quite a bit underwhelmed with the PV200/600 but systems, tastes and synergies might differ obviously.Thanks very much. It is very gratifying to hear this. I try my best not to fill up space with BS when I post. If your taste is anything like mine, you will love the combination of the F2a’s with the PV200/600.
What tubes are you currently using in your TRP?I was quite a bit underwhelmed with the PV200/600 but systems, tastes and synergies might differ obviously.
