Hadn’t heard of Globe 80. Which have you liked?Siemens F2a and Globe 80
The older the better.Hadn’t heard of Globe 80. Which have you liked?
A while ago, I received a doa RCA globe 80. After that experience, I started using a Spanish Marconi U50/80, which I thought would be similar. I liked that a lot, but not as much as I liked the PV200/600. I guess that our tastes differ.Siemens F2a and Globe 80
What a beautyMy A3 VC/Balanced arrived last week! I was going to let it burn in on the stock tubes (Shuguang 5C3S and 6550B quad), but true to form, I had the supplied tubes and fuse swapped out within the first hour of it being powered up lol.
So any observations on sound differences moving forward will be based off of the current A3, Sophia Aqua II 274B, Siemens F2A, and SR Master fuse combination. I can at least confirm that swapping in all of those at once was a significant jump forward in overall sound quality versus the first hour of playback. So much better in fact that I had only intended to check out the tube differences briefly, and when I went back to stock it was like the sound (which was huge!) had been put back into a box. Nope, gonna run what sounds the best!
I did try a few different regulator and output tubes as I swapped in different combos. A Sophia Princess 274B and an EML Mesh 274B were tried, but easily bettered by the new Aqua II. I also tried KT120s and new GL KT88s, but the F2As are ridiculous. Maybe trending toward just the tiniest touch hot on the overall sound balance, but it’s already addictive and I’m hoping as everything burns in and smooths out it’ll continue to get better. It’s like putting a supercharger on a V8, you just want to crank it at every green light.
I won’t do any in depth discussions about sound until the combo has more time on it, but I can say it is a significant step up from the B3/E53 I had previously.
I can also happily confirm that the Balanced version can be run with only the front pair of output tubes driving the single ended RCA outputs. No need for a full quad until you use the Balanced outputs, which is really nice future proofing for later system changes.
Cheers!
I already have my Atlantic 3 TRP, but this is really good feedback for anyone considering the Baltic and weighing whether or not the Atlantic is a material improvement. Glad it's working well for you... and helped you avoid a catastrophe in the process! (That potential short.)This TRP3/E11 is a HUGE leap forward from the previous B3/E53 that it replaced.
No kidding! It was ever so slightly touching, probably less than a mm of the spade just barely touching the other post, but enough to be slightly noticeable at higher volume and with greater dynamic swings. It was enough to steal some upper end purity from the final output, so it was really two birds with one stone.I already have my Atlantic 3 TRP, but this is really good feedback for anyone considering the Baltic and weighing whether or not the Atlantic is a material improvement. Glad it's working well for you... and helped you avoid a catastrophe in the process! (That potential short.)
But not totally ignore the love; I found a 'good deal' for a pair of F2a's in Europe so they and their adapters are coming home to papa.
I would heartily agree. I must say, I find the Bendix 6384 to be very close.You're gonna love the F2a. Just give it some time to burn in, but to me they're made for the TRP.
Now that the prices of F2a are out of control, I want to give Bendix a try. What type of adapter would you suggest for the Bendix?I would heartily agree. I must say, I find the Bendix 6384 to be very close.
Thank you.
Good day,
Does anyone happen to know if there is an alternative to the Tesla EL51 tube?
Thank you very much for your response.
