Magico M7 2023
Not sure a pair of subs would be enough to keep up with the M7's bass output.
Magico Titan subs are designed to work with the M9s or the M7s.
Reactions: AudioGod
Reactions: AudioGod
Presume you mean M9s bass output. ie, M7+ dual Titan subs (4 x15" cones) would not keep up with M9s bass output.
I think the bass output from an M7 + dual Titan Subs would be different than the M9s bass output alone...ie, the M7 + dual Titans would probably create greater more immersive sense of venue because it is moving more air. But the design of the M9s might enable the articulation and snap/power of bass to be greater even if the overall scale/sheer raw power might be less.
Reactions: AudioGod
M7=$375K
2 Titan subs -$64K
Total is $440K
So yeah, a much better value than M9
Reactions: AudioGod
Reactions: ScottK and AudioGod
XV. 1. I don’t see a signature on your post. Someone told me that you are a dealer. If that’s the case you do know it’s appropriate to list on WBF that you are a dealer and not just say normal user, right?
if you are not a dealer, I apologize, but if you are then it makes a lot of sense why you have trolled me and other people for several years on WBF.
LOL - No I am not a dealer in any way. If I was, at least I would be getting a 50% discount.
Just a simple consumer and music lover that needs to save $$ to afford these exorbitant prices of hi-end hifi these days.
BTW - bringing up the ridiculous high priced of high end for discussion is not trolling.
Then sorry, someone told me that you were a dealer in Australia.
Thank you for asking me directly as whoever told you is clueless.
OK a dilemma
1 million budget
M9+ $250K electronics
Or M7+ $625K electronics ? :)
That is an odd dilemma.
Of the limited people I know who would spend $1 million for stereo, they would start with the M9 and $250K electronics and then if over time they realized they need to go over budget, they just go over budget.
Otherwise, they really don't have or want to spend $1 million on their stereo so they'll just end up buying an M7 and spend whatever they need on their electronics.
I wonder if the dealers can chime in on this.
Reactions: AudioGod
It's all over the map. All customers are different, with different budgets, sonic requirements, WAFs, available rooms for audio, even if they are gazillionaires. I have several customers in NYC that live in $50M-$100M residences and within those "humble abodes" they end up with very small rooms that are available for audio.
I have other customers that live in a $300K home and have close to a $1M audio system.
There are no guidelines other than on audio forums. In the real world customers do the some crazy things.
For the industry yes ;) .
On topic i assume the M7 will be in munich as they are a lot easier to transport
I know nothing, but I would think that Munich will be interesting:)
There is even another category :
" Audiophiles " with no room / no system , the only thing they do is talk about systems on audioforums
And they're the ones who know the most and are free from error.
