Site Founder, Site Co-Owner, Administrator
Lukasz seems to have this part figured out re manufacturerHence the Lampizator interface will use a 5 pin XLR cable in stead of FSP/QFSP allowing for more exotic cables to be used.
ohh I see answered
Sending the unit back for retrofit certainly seems the most economical but as stated it is my hope to have both Horizon's present for purposes of comparing Horizon with USB to Horizon with XDMI nativeyes. I wanted to be 100% certain I will have native XDMI for the event
Now that is commitment, Steve W. Not to mention meriting commitment. . .yes. I wanted to be 100% certain I will have native XDMI for the event
Good evening Steve,Sending the unit back for retrofit certainly seems the most economical but as stated it is my hope to have both Horizon's present for purposes of comparing Horizon with USB to Horizon with XDMI native
Good evening Steve,
Will you also be testing XDMI/AES-EBU ?
Cheers,
Thomas
Steve you ever get my adoption papers, notarized ?Sending the unit back for retrofit certainly seems the most economical but as stated it is my hope to have both Horizon's present for purposes of comparing Horizon with USB to Horizon with XDMI native
Rodney, could you still adopt me if that goes through?Steve you ever get my adoption papers, notarized ?
It has always been my goal to always play my digital files pure native so as Emile stated I have no desire whatsoever to do that comparisonGood evening Steve,
Cheers,
Thomas
Wow! Very impressive Steve, you will have many of the options so many of us are curious about...Plus it appears you will foster some members...I thought it would be somewhat newsworthy to have this follow up post re the Horizon and Native XDMI . It has always been my intent to have native XDMI to the Horizon if and when Emile can find time to take the long trip to SoCal to highlight the Olympus, I/O and to fully be able to compare the internal DAC on the Olympus to Native XDMI on the Horizon. Suffice it to say I took the plunge and ordered a Horizon loaded with XDMI , rather than USB. I also suspect that Lukasz has looked into the cable needs to make native XDMI operational and Im reasonably sure he has a source to manufacture the necessary cables . I'm hoping that it will be possible to have both Horizon (USB with JL Audio and XDMI native) DAC's present to be able to compare the two....and yes I stuck with the Mallory copper top version just as I have now
“… I keep asking Emile if there was a way to use a tube with the analog card”IMHO I feel that XDMI native with the Horizon has been a much quicker turn around than I ever expected BUT this is a collaboration of 2 of the greatest minds in today’s digital arena and to read Lukasz posts from Oldenzaal where he heard XDMI solidified my belief that XDMI will be truly something great. Plus Lukasz was so taken by it he gave his immediate decision to throw into the development of XDMI on the Lampi side. And here we are in a matter of a few months at most with a working solution.I still believe Emile is being very tight lipped about this anxiously waiting for user feedback. As I said my first test will be with the analogue card. I expect that to be what those of us who use external DACs will compare. I know a lot of Olympus users plan on only using the internal DAC. Reports out of Oldenzaal confirm it to be something special. I keep asking Emile if there was a way to use a tube with that analogue card![]()
You missed my point.“… I keep asking Emile if there was a way to use a tube with the analog card”
That might be your tube preamp!
As things have progressed meanwhile I now feel more comfortable to share my personal SQ ranking:
Olympus XDMI - Lampizator Poseidon -120%
Olympus XDMI - direct analogue out - 100%
Olympus USB - Lampizator Horizon - 65% (we did actually manage to improve the Olympus USB performance a bit more, it was much further behind priorly)
The Poseidon I have here has no USB input, only XDMI native, hence I cannot do a direct comparison to USB, it also has “cheap” made in china tubes fitted as I don’t have upgraded tubes for it with the exception of the rectifier which I exchanged for a Telefunken RGN2004 which I prefer with it. My Horizon has Telefunken RGN2504, Chalmers RS1003, and ITT Lorenz C3g fitted. Another interesting observation is the interface cable conductor quality matters a lot in this particular application.. Hence the Lampizator interface will use a 5 pin XLR cable in stead of FSP/QFSP allowing for more exotic cables to be used.
Photos of the tube complements used for this particular comparison:
