Emile. What preamp was used here ?
Or was it direct to amps ?
Will the Olympus analog Xdmi out be much better with top preamps ?
Conrad Johnson ART-88.
IMHO a pre-amplifier is mandatory for best performance.
I keep asking Emile if there was a way to use a tube with that analogue card![]()
Your honesty/transparency is well noted and appreciated!Well indeed if you have a strong preference for some things only tubes do, like an infusion of air, a different rendering of tonal textures, the way they can put a spotlight on foreground instruments, then there’s no substitute. This applies to any gain / amplification stage, DAC output stage, pre amplifier, power amplifier.
Quite obviously this is not everyone’s preference, as this tends to come at a cost, like a less tight, less controlled, less powerful lower register, increased overall noise levels, no inky black backgrounds, and although those tube spotlighted foreground images can appear to be very transparent, overall transparency levels are lower.
Basically this is a tube versus solid state preference thing, and therefor highly personal.
My personal preference favours the tube type of presentation which is why I rate the Poseidon 20% higher then direct analogue out. But those favouring solid state characteristics may not agree with my assessment at all, if you prefer ultimate precision, maximum detail extraction, ultimate clarity, from all the way on top down to the lowest sub bass levels, with impressive speed from a 100MHz+ bandwidth battery powered output stage, then the direct analogue output option might very well be all you want.
The bottom line here is that if you’re into tubes, native XDMI to a Lampizator DAC will not disappoint.
As personal preference is really a big part of what one may prefer, and XDMI analogue out contains an analogue amplification stage, it’s beyond “just” better digital technology. Hence I am indeed very eager to learn how people perceive the sound of XDMI, in whatever way it’s utilised.
Also with the Lampi Poseidon that is supposed to be an excellent preamp as well as an excellent DAC?Conrad Johnson ART-88.
Pity, that would be most interesting.I did not try bypassing my preamplifier.
Purely speculation but I suspect direct would be a presentation sounding as if on audio steroids...Pity, that would be most interesting.
Fantastic.Conrad Johnson ART-88.
Or perhaps the Conrad Johnson ART-88 is the best tube preamp that Emile could find. I wonder what would be rank in terms of best tube (or hibrid) preamp among: VAC Statement ($70K), Lamm L1.1 sig ($55.3K), Riviera Labs APL10 SE ($47K), Conrad Johnson ART-88 ($28K), Ypsilon PST100 mk2 SE, VTL 7.5, Audio Research, CAT, etcFantastic.
So it looks if you add a top preamp to the analog XDMI output , With above 50K sticker price this should give it a very big improvement .
Of course you were joking. The point, from my perspective is whether the analog out will be bettered by a native xdmi dac or not.You missed my point.![]()
I couldn't agree more in regard to the preamp/line stage having a profound influence...Of course you were joking. The point, from my perspective is whether the analog out will be bettered by a native xdmi dac or not.
My personal experience is that the preamp has a profound influence on overall sound. If forced to make a choice for $$ reasons, I would part with my dac before my pre. It will be fascinating to see how this shakes out.
Fantastic list of top performers.Or perhaps the Conrad Johnson ART-88 is the best tube preamp that Emile could find. I wonder what would be rank in terms of best tube (or hibrid) preamp among: VAC Statement ($70K), Lamm L1.1 sig ($55.3K), Riviera Labs APL10 SE ($47K), Conrad Johnson ART-88 ($28K), Ypsilon PST100 mk2 SE, VTL 7.5, Audio Research, CAT, etc
also totally agree. I always tell friends when they ask about tubes and where they should start, the preamp is my number one recommendation and since my entire system is tubes I really look forward to hearing the XDMI analog DAC played through my tube preampI couldn't agree more in regard to the preamp/line stage having a profound influence...
I just had a worrisome thought and thus a question to Emile and those in the know...In order to run the analog card to the preamp am I correct in assuming that the card only has AES/EBU output which, if correct, requires an XLR cable from the card to the preamp.......if that is the case my great idea just collapsed as Lamm does not use XLR in to the preamp...only SE. The preamp does use XLR out from the preamp to the amp but it is pseudo balanced (one pin is shorted making it effectively a SE cable)also totally agree. I always tell friends when they ask about tubes and where they should start, the preamp is my number one recommendation and since my entire system is tubes I really look forward to hearing the XDMI analog DAC played through my tube preamp
Exactly.I just spoke to Emile who reassured me all is well as the card is RCA analog out![]()
sometimes the squirrel gets the nut......Exactly.
We are suffering as it has no Balanced audio XLRs.
You are just perfect using RCA direct from analog outputs.
Bit in Emile we trust to get balanced XDMI audio card one day
Indeed. That is certainly the way I am leaning, whether or not tubes are involved. Though I recently have started getting back into tube gear after a long absence.Of course you were joking. The point, from my perspective is whether the analog out will be bettered by a native xdmi dac or not.
