Shoot a message to support@taikoaudio.com and we can take a look.Someone I know has bought a Horizon and an used Taiko. Now is trying to make them work together.
My closest audio buddy who has an exact same combination (Horizon and Taiko, both bough in 2022), never had those problems.
We have various new and exciting developments in the works. Here are some tidbits: XDMS is moving ever closer to Beta status, we are working on balanced outputs for the Olympus XDMI DAC board, and are working on a revolutionary manner of volume control for said board.“The Extreme is here to stay and will get a lot better, I'm under a gag order by an overwhelmed support team, but once we're through the Olympus launch, you can expect some major updates coming up for the Extreme”
Keeping this thread alive for ‘25.
Emile, are there any crumbs of information you could throw our way without being set upon by the team ?
I understand a new backend for XDMS is due soon but anything else on the hardware or software side in Q1/2 ?
We’re all eager to get close to Olympus levels without adding an I/0.
Cheers
Blue58
I am sure you will have some surprises for the Extreme after you ship all the remaining backlog of Olympus. You should be receiving 150+ Extreme as part of the payment for the Olympus, so you should come with some upgrades to help sell them.We
For Extreme, we also have some exciting ideas that will elevate its performance but this is currently still in the concept stage, and we do not yet have a defined timeline for the rollout. For now, we must focus on fulfilling the overwhelming number of Olympus orders. That said, you can be sure that we will continue development for Extreme!
Digital inputs are also a consideration, but volume control and balanced outputs will likely be released first.I am sure you will have some surprises for the Extreme after you ship all the remaining backlog of Olympus. You should be receiving 150+ Extreme as part of the payment for the Olympus, so you should come with some upgrades to help sell them.
"we are working on balanced outputs for the Olympus XDMI DAC board, and are working on a revolutionary manner of volume control for said board." I hope that you include at least two digital inputs (AES and SPDIF Coax), even if optional, for the XDMI DAC board.
Dear Christian, for those who have digital inputs from either video or from a CD/SACD player, it is simply not possible to replace the regular DAC with the XDMI DAC until it has digital inputs. I hope you reconsider and put this feature as a priority, even if optional.Digital inputs are also a consideration, but volume control and balanced outputs will likely be released first.
No worries, we understand the use case, and this is most definitely being considered. We just cannot provide timelines on the release of features that, for now, only exist in Emile's head. ;-) My earlier comment that volume control and balanced outputs will likely be released first is also an educated guess, not something already set in stone. Rest assured Emile will be the first to post news about these topics as soon as something materializes.Dear Christian, for those who have digital inputs from either video or from a CD/SACD player, it is simply not possible to replace the regular DAC with the XDMI DAC until it has digital inputs. I hope you reconsider and put this feature as a priority, even if optional.
Out of necessity I'm using an Anthem STR preamp with ARC. It's done a nice job in my difficult room so I plan on keeping it. I used to have an Extreme but a bout of severe tinnitus convinced me to sell it (and almost everything else). Can anyone give me some advice as to whether the DSP the Anthem ARC uses will seriously degrade the SQ of a Taiko Extreme, switch, router and DSD? I'm thinking of diving back in with Taiko. Based on what I've read about the Olympus DSP is a non starter but would that be true for the Extreme combo as well?No worries, we understand the use case, and this is most definitely being considered. We just cannot provide timelines on the release of features that, for now, only exist in Emile's head. ;-) My earlier comment that volume control and balanced outputs will likely be released first is also an educated guess, not something already set in stone. Rest assured Emile will be the first to post news about these topics as soon as something materializes.
There is always the risk of hearing a negative impact from DSP. It's just that the Olympus' inherent noise levels are so low that you will hear these influences much more clearly. With the Extreme, the USB connection is what ultimately limits how low-noise it can be. Therefore, the inflence of external noise will indeed appear relatively much smaller. So, the Extreme will indeed be relatively less affected by DSP than the Olympus.Out of necessity I'm using an Anthem STR preamp with ARC. It's done a nice job in my difficult room so I plan on keeping it. I used to have an Extreme but a bout of severe tinnitus convinced me to sell it (and almost everything else). Can anyone give me some advice as to whether the DSP the Anthem ARC uses will seriously degrade the SQ of a Taiko Extreme, switch, router and DSD? I'm thinking of diving back in with Taiko. Based on what I've read about the Olympus DSP is a non starter but would that be true for the Extreme combo as well?
Thanks Christiaan. I sold my Extreme before the switch, router and DCD were available and I was running TAS since XDMS hadn't been released. I did have the USB card but otherwise my Extreme was "original". Based on what I've read I'm assuming the Extreme with the new support gear and software is significantly better than what I had so I guess I need to decide if the loss in SQ the DSP will cause will be more than offset by the new hardware and software.There is always the risk of hearing a negative impact from DSP. It's just that the Olympus' inherent noise levels are so low that you will hear these influences much more clearly. With the Extreme, the USB connection is what ultimately limits how low-noise it can be. Therefore, the inflence of external noise will indeed appear relatively much smaller. So, the Extreme will indeed be relatively less affected by DSP than the Olympus.
With that said, the influence of DSP, as well as other programs, will normally be largest when the software is running on the same platform, which is why we do not support running additional software on the Extreme. DSP run externally (as on your Anthem STR) is a different matter. Although it can still be a case of win some (usually precision), lose some (usually naturalness), depending on the room and what is required of it, the net result can be better with DSP in place. It's very much a personal matter.
Now, inserting an Extreme Server into this scenario, the result will still be what you know and love about the server, but proportionally altered by what your DSP does.
The Router, Switch, and DCD certainly moved the goal posts and I'd wager the result will still be clearly audible even with your STR in place, but there's really only one way to find out for sure, which is an audition.Thanks Christiaan. I sold my Extreme before the switch, router and DCD were available and I was running TAS since XDMS hadn't been released. I did have the USB card but otherwise my Extreme was "original". Based on what I've read I'm assuming the Extreme with the new support gear and software is significantly better than what I had so I guess I need to decide if the loss in SQ the DSP will cause will be more than offset by the new hardware and software.
Very true but that's pretty difficult to arrange.The Router, Switch, and DCD certainly moved the goal posts and I'd wager the result will still be clearly audible even with your STR in place, but there's really only one way to find out for sure, which is an audition.
Ken — we can probably arrange this for you . Give me a call to discuss sometime tomorrow. We will just need to arrange around auditions at the shopVery true but that's pretty difficult to arrange.
That project turned onto the Olympus and xdmi. I do hope for some trickle down tech to the extreme.replacing the USB output on the extreme
exactly, but hopefully the trickle down includes the usb ouput since it is the single noisiest item.That project turned onto the Olympus and xdmi. I do hope for some trickle down tech to the extreme.
If I recall Emile's words correctly, with the USB card they had reached the maximum they could achieve in noise reduction on that interface. This led them to develop a completely new interface, XDMI, but unfortunately the implementation of XDMI in the Extreme did not produce any great improvements.
