1. I never looked for bit errors, I assume they are there.I suppose one would see bit errors then, with CDs?
And CDs used to hold data, would need magnets in their readers to prevent data corruption?
I am not even sure how, or if, a magnet would affect a static charge.
2. The *moving magnets* produce an electric field.
The electric field neutralizes the electric static charge on the CD. The charge on the CD is produced by the friction of air molecules rubbing against the plastic layer of the CD. After a couple of plays it’s prudent to “demag” the CD again. The static charge is very persistent and will remain on the CD for a long time. Time to intervene.
If ^that^ was the case, then it would result in corruption of data on CDs and make things like excel spreadsheets in error… which we have never heard of…
There is a big between corruption of data on the CD and producing errors when the data is read by the laser. People often assume Reed Solomon and the laser servo feedback system correct all errors. Lots of things have the potential to produce errors in music CDs - vibration (internal and external), scattered laser light inside the transport compartment, fluttering and wobbling of the disc whilst playing, to name a few.
I am not sure but it seems the errors are not the main reason for degraded sound of transports. most transports read data (zero ones) correctly but the output digital signal quality is different.
- SPDIF is a weak link between transport DAC
- ground loops between transport and dac
- noise level in circuits or the power supply of transport
- vibration effects on transport output signal
I think great digital designers should explain why transports are not equal.
What kind of errors do the wobbling and fluttering produce?
And how does the vibration manifests as data errors?
I prefer not to broach the physics of how CD demagnetizers work, but my recent 2 months‘ and continuing experimentations with these devices including the Walker Audio Talisman, and my own designed from scratch degausser prove to me they work when used correctly - when Lloyd Walker’s instructions are followed to the letter - spinning the on a fingertip of one hand whilst holding the demag over it for 3 complete revolutions. Repeat for the other side.I am not sure but it seems the errors are not the main reason for degraded sound of transports. most transports read data (zero ones) correctly but the output digital signal quality is different.
Hi,When the day dawns that we can explain exactly, at an atomic level how an electric current propagates through a cable, then we may be able to explain how run in works. In the meantime, all we have is subjective ‘expert ears’ and speculation (unproven hypotheses). In the past 4 years I have run-in a large number of power supply upgrades that involved Mundorf Silver/Gold cabling and gradually I observed the exact same pattern each time, which fit with the above descriptions. It also took up to 500 hours to achieve the level of perfection I was expecting
Some would call it expectation bias or ‘user conditioning’ but that infers a conscious component to the process. That would not explain that during the running in process I would often catch myself using my iPad to surf internet items while music was playing, whereas the fully run-in system was overwhelmingly involving and generated such intense emotions that stray thoughts were simply obliterated. That’s an entirely subconscious reaction.
Also, let me ask you. Can you explain, again at the atomic quantum level what happens when a cable is degaused or what cryogenic cooling does, because they both make changes to the atomic or crystal structure. In the case of cryogenic treatment one can actually see the changes to crystal boundaries Under a high power election microscope.
Our level of knowledge of how cables affect the resulting sound quality is still pretty much at the ‘unconscious ignorance’ stage…..we don’t know what we don’t know. All denial of the subjective observations of change achieves is to ensure we remain at that level. The problem isn‘t that the changes don’t happen. The problem is that our knowledge is insufficient to explain why.
I agree that there is a dilemma of 14 day trials vs. 500 hour break-in, but that doesn‘t mean that the break-in doesn’t exist or take 500 hours. It just means that either demos need to be done with pre-run-in components, or that potential customers take an initial listen and decide if the changes heard in the initial period warrant purchase. This has been my approach. Over the years Ive learned that if a component sounds really good and brings specific improvements at the onset, it will eventually sound even better, but will sound considerably worse during burn in, On the other hand, if I don‘t like what the component does after say 5 days, then burn in won’t suddenly transform it. There has to be initial benefits before everything goes to hell for a few weeks until the final transformation happens.
White and yellow color or later zero type?Hi,
I also have used as interconnects RCA Mundorf SILVER /GOLD cable of 2 type. One with PTFE insulation and one without any insulation but inserted inside a larger tube of PTFE. The impression was that the cable with PTFE insulation was faster to be burned in with music.
They were used to connect Pre Phono to Amp.
Rgds
Adelmo
Hi,White and yellow color or later zero type?
Sorry zendo not zero
All fine, the later zendo wire have 0.2 mm diameter it sounds a bit smoother, more air needs break in150 hours i think like the caps from mundorf my opion View attachment 125440
I prefer not to broach the physics of how CD demagnetizers work, …
Especially here, right? Wink, wink^that^ seems wise.
How do you spell quantum magnetism?
Please scroll down to Introduction, page 7 paragraph 1 for brief overview how magnetism works, do not go past p 7 if equations.give you the willies.
