I am sure the Organic (power cord you mean?) would work very good on your Metronome. The vocals will be spot on with this cable. I would prefer to have something different on the Dac to get the maximum bass resolution.Thank you Geir, i found the same difference between my Organic Réference speaker cable and the Serenity speaker cable.The Argento is more natural with my Pbn audio Sammy. Perhaps the Organic audio will be better my metronome DSS Streamer...
Thanks for your recommandation about the power cord ! préviously i was talking about the difference between AES Organic Référence and AES Argento Flow.I am sure the Organic (power cord you mean?) would work very good on your Metronome. The vocals will be spot on with this cable. I would prefer to have something different on the Dac to get the maximum bass resolution.
When the day dawns that we can explain exactly, at an atomic level how an electric current propagates through a cable, then we may be able to explain how run in works. In the meantime, all …
Yes, it's true. It is the same principle on the PCBs. The energy is transferred between the conductor and the return path.The electric field propagates within the dielectric, which is essentially on and outside of the surface of the conductor.
It is not rattling electrons out of atoms as a current of electrons, but it is modelled that way.
With something like 50 years of experience in Hi-fi I’ve been lucky enough to experience a wide range of cables of every description. Interconnects (balanced and single ended), mains power, ethernet, USB, phono, DC. At the very outset, burn-in of cables was not a reported phenomenon and I was not aware of it at all so for me, at the time, it simply didn’t exist.I just experienced cable break in again firsthand.
10 Days ago, I bought a new set of the AudioQuest Thunderbird XLR 2M interconnects.
First impression, they sounded good, but then after about 30 hours of usage the music started sounding very closed in and with limited high frequencies. This continued until about 130 hours of music play time.
Then at this time, the cables started to open up and began to sound better and better each passing hour. I knew at the beginning they would come around because they sounded ok at first until the break in process started. But now they have way surpassed that original sound. Now the soundstage has become huge with fantastic frequency extensions. Very pleased with the results.
Scientifically I guess we can't prove cable break in is real, but with good equipment, good ears, it is clearly a real event.
ozzy
Nope, your ears are simply getting used to it, plain and simpleI just experienced cable break in again firsthand.
ozzy
I built a jig to burn in power cables off line without any listening, because the listening can be slightly excruciating. The difference between a partly burned in and a fully burned in cable isn’t subtle. One has clear anomalies, the other doesn’t. One is fun to listen to, the other isn’t. No user acclimatisation involved, just a straightforward, “does it sound great’ yes of no?”Nope, your ears are simply getting used to it, plain and simple
New one to ignore, plain and simple.Nope, your ears are simply getting used to it, plain and simple
He can / will just post in other places and folks will say "hell ya". Issue resolved.New one to ignore, plain and simple.
Well I don't have to look at here with hitting ignore. Wish he would go back to ASR or Audioholics.He can just post in other places and folks will say "hell ya".
