Will there be an DMC 15SS 2
Adimon
136
10
925
Now that Spectral released the DMC 30SS 2 will there also be an upgrade for the DMC 15SS?
Hi...did you ask Spectral? Most manufacturers are reasonably forthright about near-term plans to bring out upgrades.
Need some advice before upgrading.
Whats best to do first , upgrade from DMC 15ss to 30ss or from DMA 100 to 260?
Second Whats is the audible difference between RCA and Balanced?
Adimon,
What is motivating you to upgrade? Are you thinking of moving to less efficient speakers, for example?
Ronald
Hi Ronald,
Reason to upgrade is to enjoy the improvements of new Spectral gear.
I heard the 260 and i was shocked by the sound.
Btw the speaker is not the problem, Avalon ascendant.
I've never heard the difference between balanced and single.
Hi Ronald,
Ah, okay, Adimon. Thank you for the reply. I'm afraid I was asking for selfish reasons. I've owned my DMA-90 since I purchased it new in 1995 or so, and each and every time I use it, I am so terribly thrilled with it: its appearance (its relatively tiny size), how quickly it warms up (and how, not being Class A, it doesn't throw off much heat and dramatically increase my utility bill), and especially how it sounds (it is so accurate and discriminating, and its noise floor is so incredibly low)! Your 100S shares all these characteristics, too, I think. I'm seriously considering moving to some relatively inefficient ATC speakers, which of course means I would need to upgrade my DMA-90. And, frankly, I'm conflicted!
Good luck with your upgrade. I hope you'll let us all know how it turns out.
Best Regards,
rx7audio
Hi Adimon,
Regarding your post #3, if I were you, I would upgrade the DMC 15ss to the 30ss. My reason is that based on your post #5, it seems like your power amp and speakers are already well matched and in my experience, using a better Spectral preamp or linestage always results in more improvements.
