+ 1
Phase responce threeway active speakerView attachment 126684
What is that the electrical phase??
Rob
+ 1
Many attributes of certain old speakers offend sensibilities. For example aluminum voice coils are the shit.
Group delay of the drivers, xover point 600hz and 2.3khz, steep-edged filters, this is what the phase sequence looks like. Impulse-optimized loudspeaker (3 way) to simultaneously address the drivers. With active speakers, the treble and midrange are often slowed down so that they work at the same time. The Neumann pictured does this almost perfectly.What is that the electrical phase??
Rob
Sorry Stephan using very direct expression on my last post. I just wanted to point out how frustrating those beryllium drivers on Yamaha speakers. I think we both agree that they don’t sound good for us.You disassembled the tweeter and midrange domes so they could actually touch them. You are the best, congratulations. The bass is papercone with Zylon coating. With the new 5000, Yamaha had learned from the past. They made all the drivers out of Zylon. It sounds more homogeneous. Zylon is harder then metal or carbon is used in racing boats. only for information.
All fine, don't fits my tube amplifiers and my taste. But anyone who owns these classics should read them carefully and recreate them.Sorry Stephan using very direct expression on my last post. I just wanted to point out how frustrating those beryllium drivers on Yamaha speakers. I think we both agree that they don’t sound good for us.
Why out of curiosity? Durability like breakage from flex?
Rob
VC's should never flex. The leads to them are not the same material.
I thought some of the older compression drivers routed the VC wire through the tangential surrounds and it was a common failure point? Maybe not?
So what's your objection to aluminum?
Rob
Sure but again the leads are not the same as the VC. That is why on cones of lots of drivers you see the two dimples, it is where the leads are soldered to the VC.
VCs are not braided, they're just a solid core. That is one easy way to tell looking behind a driver.
Bonzo, you could not convince him to rev up that turntable? Interesting shape and size for the Eurodyn baffle. Subwoffers in the ceiling? I've only heard that once at Romy's place.
good old blu tack...is that heat-sink putty on top, or pigeon poop?
Just call Shahinian - (631) 736-0033 - they'll explain the connections (not obvious). I've never seen a manual for their speakers (which is, of course, odd)!Looking for some advice on how to make speaker cable connections on Shahinian Diapason speaker. Thank you for the assistance!
