Affordable ethernet filters
SoundMann
498
311
133
Denver, CO
Hey everyone. I am looking for a truly affordable ethernet filter that actually works. Noise is the enemy which causes jitter, right?
I am using an ethernet cable between my router and computer, which inturn feeds my dac thru a SilkLine USB to SPDIF converter which filters and reclocks the signal.
So adding an ethernet filter should be the last reasonable step in improvement?
Are there affective filters that sell for under $100 US?
I have two of these. They work well. iFi LAN iSilencer - LAN Signal Noise Filter - Remove Electrical Noise - Ethernet Isolator for Hi-Res Audio Systems (RJ45) https://a.co/d/hbyz3KJ
I have a couple of the iFi LAN Silencers, they do work. But I think the Stack Audio SmoothLAN goes further and cleans up the sound more. It is a bit more than double the price of the iFi
Stack Audio SmoothLAN Ethernet Filter
I love the SmoothLan so much, i bought two! Run one from the wall plug to the Switch, then the other from the switch to the streamer.
I have the iFi, DX Engineering (best used in pairs), EMO en-85e, EMO en-30, Stack Audio SmoothLAN, and a few others. The standout for consistent sound quality improvement has been the SmoothLAN in both my systems.
The ONLY downside I can think of is that it is only 10/100mbps. No gigabit. Far more than enough for streaming audio, but for, say a music server.....where it is polling SQL tables/loading images/grabbing metadata/etc.....this may not be preferable.
I run an EMO en-85e on my Roon Nucleus Titan and SmoothLANs on both of my endpoints.
UPDATE: I'm BJC Cat6A all the way through. Plastic connectors and floating shields at both ends.
Reactions: Republicoftexas69
The iFi did a better job of eliminating nasties in an overall sense, in both my systems. BUT, it sacrified detail and dynamics and scale. Inoffensive and smart money.
The DXE's were overall more revealing and pleasing in my system, but I'm addressing network nasties from multiple different directions. For a first network audio mod, iFi is likely a safe bet <unless> you find your current system overly dark.
So of the products listed, I am currently looking at the iFi vs the DX Engineering. Which is better?
In comparison to the Stack or the EE1 the iFi is well 3rd.
Reactions: NaimYourTubes
I am looking to reduce both haziness and fatiguing digital artifacts from my otherwise neutral and revealing system.
I prefer the sound of vinyl over digital, so I prefer a smoother and more organic presentation overall.
So I am looking for a balance between the above, while maintaining enough soundstaging, imaging and resolve to satisfy.
Would you say that the iFi is more like analog?
Hello, I thought I would list out all of the filters that I know of. I have tried all of the ones in this list except the DX Engineering and the smooth LAN. Here is a link to a reveiew that compared the EE1, Aardvark Classic and the CAD.
DX Engineering ISO Plus 2 -- $82
iFi LAN Silencer -- $89
Stack Audio Smooth LAN -- $305
English Electric EE1 -- 300 Euro
Aardvark Classic -- $450
Aardvark Ultra -- $850
CAD Ethernet Control -- $1250
Network Acoustics Muon Pro -- 1829 BPS
EE1 is on a special promotion at the Cable Company right now.
I just purchased the iFi. But I have another idea that may further improve its performance, and that is to use an ethernet pc card to reclock the signal.
But was it the only filter in your network?
At the time. l gave it to my son.
I tried the following in this order.
IFi LAN
EE1 (was better than the IFi)
Stack SmoothLan (better than the EE1 and really performed with better higher quality cat8 with modifed shield tie)
NA Muon Pro. just edges the SmoothLan but for a considerably larger investment.
To me the winner was the SmoothLan using Modified DH Labs CAT8 ethernet cables Total $610 total vs the $1700.00 plus for the Muon Pro
I wonder how the new eno2 will fit into these comparisons?
EE1 (was better than the iFi)
I read several reviews which stated that the EE1 emphasized leading egdes causing fatigue.
I am looking for a smooth, fatigue free sound.
Also, iFi makes a more elaborate pro model for $300. Has anyone tried it?
