?? I must not understand the question. Our MP-1 and one of our amps does have that 'transfer function'. Power amps must not have too much gain if they are not also higher power. Power amps by themselves don't have enough gain to work with a lot of sources (digital being the sometimes exception). So it sounds like you're asking why we don't make an integrated amp using our OTL approach and the answer is the product would be far too large and cumbersome. Plus- why would you when our class D can do the job and not sound appreciably different?
I have to imagine that you've not paid much attention to what I've previously written on this matter elsewhere. Our class D has a distortion signature very much like our OTLs and similar to SETs in that the 2nd and 3rd harmonics are the predominant distortion products- this because the non-linearities of the encoder scheme and the deadtime both impose lower ordered harmonics.
Early prototypes of our OTLs employed feedback. The original MA-2 had switchable feedback. So that goes back about 45-50 years. Not sudden- just sudden to your awareness of what I might be doing in spare time
(FWIW dept.: 'power source' not 'current source'.)
The difference between the class D and our OTLs has been described by a number of people independently of each other but in a strikingly similar fashion- the difference being that the class D is slightly more transparent in the mids and highs but otherwise has the same relaxed character of the OTLs; the easiest difference is heard in the bass (and this is coming from OTL customers of ours...)- since the class D acts as a voltage source and the OTLs do not the bass difference is on that account. In most cases this means the bass is better too.
The reason this seems to be such an about face is because for most of my life the devices needed to really apply the kind of feedback needed
if you are going to use it at all simply didn't exist. That changed about 20 years ago and it took a while for that to sink in to my consciousness. Once I realized that things had changed I also realized that feedback could finally be applied properly so that it would not cause harshness of its own. That was about 5 1/2-6 years ago, about the same time I realized that class D had to be taken seriously (and the time when we embarked on our class D project).
Nowadays you can buy inexpensive Chinese class D amps that sound better in many ways than the best SETs. Yes, I said that. I've had several customers comment to me about that. SETs and our OTLs are both solutions about what to do when feedback is shown to not work; the problem now is what do you do if feedback can now be applied properly?? Just put our collective heads in the sand as if nothing has happened in the last 20 years? As an amplifier manufacturer that would be foolish because the market will leave you behind. I imagine a lot of SET owners and manufacturers really won't like hearing this news and will be looking for ways to deny it. It likely does not feel good to know that a $100 class D amp can sound as smooth but with more detail than a $10,000 SET...
Look at it this way if you want: its not a measurement thing (even though most class D amps measure far better than most SETs), its a
listening thing. IME class D amps vary in sound far more than tube amps do from the worst to the best. This means if you heard a class D amp you didn't like (and I think that's a fairly common experience)
it says nothing at all about how good a class D amp can sound, just like if you heard a junky tube amp compared to a really nice one. I hope you don't think we haven't listened to this amp and done a fair bit of comparison
; one nice thing is that it showed us we were on the right track with our sonic goals with our OTLs all along.
