A/D converters for Needle Drops
At full tilt boogie you can go with the Grimm AD1/OC1, Playback Designs MPD-5 and Sonoma workstation, which i use for a cool $40k :cool:[/QUOTE]
Bruce in your opinion how close does this system get to actually playing a record completely analog? Even with a $40k SOTA workstation can you still pick the difference in a double blind test?
Cheers,
Jason
Fremer's most used music source at audio shows is a USB drive with 24/96 files made from LP>PCM.
Which were recorded using his Alesis?
I don't know about that. He just told me 24/96 "needle drops" (yes, he used that term) :)
For some reason, I dislike the term "needle drops" almost as much as I dislike the term "harmonic spray." I personally can't get too excited about converting LPs to digital because I have no use for that in my system. I guess I would want to know why you would want to make digital copies of LPs. What are you going to do with them?
For me it's something to listen to on my headphone setup at work during my lunch hour. And eventually I'd like to have a stereo system at the lake house, it's too big of a pain to have a full vinyl setup at two locations.
I use a Metric Halo LIO-8 and Pure Vinyl. PV is a little fussy to use (especially if you want to split sides into tracks) but the results sound pretty good.
I have a lot of places to listen to music but only one with a turntable. So recording a spin every now and then gives me the opportunity to take music with me, including some only released on vinyl.
Jason
In a DBT?? Sounds exactly the same....
Cheers,
Jason
John Atkinson felt the Ayre (at 24/192) also made copies indistinguishable from the analog originals.
After I retired, I started my mammoth A2D ripping project primarily to preserve a legacy for future generations - my daughter and son-in-law and now my granddaughter, who love music - particularly classical music, but are not inclined to inherit 15,000 records and 1000+ R2R tapes. Since ripping analogue is a real time endeavor, I took a lot of time and effort including hiring consultants who were much more knowledgeable than I to determine what equipment and process to use, including extensive tests and shootouts. Although the cost of the equipment and software was expensive, including hiring experts to teach me how to use all of this stuff, it was less than even a minimum wage cost of ripping the records. As I approach the 40% stage of the project (of the projected 10,000 titles that I am interested in ripping), with something like 14TB of rips ( all at 192/24), I can see the light at the end of the tunnel, hopefully, well before I "shuffle off this mortal coil."
Are my rips better than the originals? For the original R2R 15ips 2 track, no. For the vinyl after all the clicks and pops have been removed with Izotope RX2, I think yes, particularly for my collection of rare, used Decca, EMI, RCA and Mercury classical records from the 1950's to 1980 or so.
It was also wonderful to bring a couple of 3TB hard drives with me for my annual month in London, with my little Meridian Explorer DAC and have my entire collection of Decca SXL 2000 and 6000 and Lyrita records in my briefcase, with my MacAir and headphones. When I was interviewing the Decca engineers for the book I am doing with Winston Ma, it was great to be able to play a recording that one of them did more than 30 years ago.
If you want more details, you can PM me.
Larry
Hi. I'd like to know if this Tascam could be used to digitize some of my LP collection. If I could run this through my Spectral preamp that would be great. Could I also run this thru my Berkeley DAC? Any advice/suggestions would be welcome. thanks,
Sure it can. And the great part is that it has digital out so you can use better outboard converters if you wish.
