Hello Amir. Have you ever experienced electric noise coming from the C600 power supply itself (not the preamp) ? Thanks for your answerYes , the circuits of TAD Reference D600/C600/M700 are floated and fully balanced.
Hello StefHello Amir. Have you ever experienced electric noise coming from the C600 power supply itself (not the preamp) ? Thanks for your answer
Maybe my question was no so clear... With my C600 the external power supply is producing a noise. I was wondering if it's a common issue or is it linked to something else ?Hello Stef
There is no problem with my C600 but to answer to your question how can I check electric noise come from PSU?
Thanks Alrainbow. It's acoustic noise coming from the C600 PSU. There no ground on all the TAD power plugs. I tried several power cords but no real difference. I was wondering if it was possible to be the phase...This thread has many paths and the posting seems to mix them at times
as for psu noise all psu s have ripple the ripple is most times of AC power. Now if we could make them be in sync not additive this lowers the ripple
As we connect the gain Stages.In some cases one could try to swap the input power cords. if 2 phases are used this seems to be ok in thought. If it’s 120 Volts meaning Phase to ground it’s still possible but not recommend by me.
if the input does not use the ground as a poster above said then it’s ok I feel. But if they do use the ground this then gets complicated.
PSU size is big. Is it your question?If it’s acoustic how large is the pau meaning amps
Larger transformers can be effected by dc offset and makes them him or growel
if it’s smaller like a pre amp or phono pre im
Guessing it always hums.
comment on the size please
If small no power cord or phase will help. You can place it on rubber feet and tighten all screws
Lastly place a Heavy object with a pad in between
This will absorb the vibration but make sure it can vent and anything uses is non ferrous
If I may borrow from a sign I see when traveling through small towns" We have many[Audiophiles]. Bit none to spare."We stick to our opinions for various reasons. On Audiophile matters, it is all good
It is snot so benign for matters of LIFE and DEATH. When it comes to electricity and in particular of safety ground and other lifesaving concepts, the audiophile life and that of people he/she cares or at the very least should care about, are the issues. Accepting the facts would have been the wise thing. Some prefer to debate just for the sake of being right right putting in that sense the lives of less knowledgeable people in harm's way. That is Very unfortunate.
Thanks Amir. Yes this what I have noticed too. Noise level can be different from time to time. Power Amps are very quiet honestly (I'm using 2 class D TAD M1000).Stef
I think Alrainbow is right, the DC-offset of AC line could produce acoustic noise in big transformers.
The C600 transformer is 400VA.
If you have TAD power amplifier then you should hear the same noise from Power amplifier.
AC quality is different across time and you may hear less or more noise in different times.
do not worry about lifted earth wire , it does not matter.
only big transformers have acoustic noise and and class d does not use transformer in PSU.Thanks Amir. Yes this what I have noticed too. Noise level can be different from time to time. Power Amps are very quiet honestly (I'm using 2 class D TAD M1000).
Once I tried a power regeneration device only for the preamp but the result was horrible...
Thanks again for all your answers!
