Now you should be ready for a trip to FloridaHi Elliot,
Without a doubt. Until you've seen and heard a setup master extraordinaire do his magic in your room with your own eyes and ears, you won't believe the before and after effect. It's well worth the investment and in my humble opinion, a highly recommended part of comparing any major equipment changes in your system.
Mark, I would have gladly paid more for the amps if either were true!!So Marty, does the Gryphon bring those girls to you, or takes you to the girls?
Gents, as a Gryphon owner for 11 years culminating in the Mephisto stereo (and now the Robert Koda K160 monos...also pure Class A, 230 Watts into 4 ohms)...let me make a suggestion.Wonderful post #597, Marty! Very well articulated. I have the same monoblocks, and over the years, have explored other options, but keep solidly footed with the Mephistos. There's just something very special and captivating about them, as you so eloquently stated.
They indeed run very hot - in the winter, the "are" my source for keeping the house warm, and as you state, even at that - the occasional A/C is not uncommon. In the summer, yeah - A/C is a must-have. But certainly worth it. I really like what you did, installing them in a separate room - I hope to do the same in a future listening room.
Congrats. I hope they bring you years of joy, as mine have done for me.
Regards,
V2
cute video
But for talent and style, try this one by PMJ
(Haley Reinhart rocks)
Peter, forgive me for not noticing. Please send the link. They're a hoot!Marty, I started a whole thread about this video about a year ago. I love it, er admire it, er respect it. Bass, no treble. This one video makes me wish I could stream and have a large screen between my speakers, with lights out.
I had to put a dedicated HVAC in my sound room to cope with the heatGents, as a Gryphon owner for 11 years culminating in the Mephisto stereo (and now the Robert Koda K160 monos...also pure Class A, 230 Watts into 4 ohms)...let me make a suggestion.
Check out the Noctua 12cm super-silent ultra-low noise (8db) fans.
NF-S12A ULN
The NF-S12A marks the third generation of Noctua’s signature S12 series quiet case fans, which have received more than 250 awards and recommendations from the international press. Featuring a further refined blade design with Anti-Stall Knobs that works in tandem with the new AAO (Advanced...noctua.at
They are so quiet you dont know whether they are on or off unless you are looking at them spin...and with a thermometer setup to turn them on/off at whatever temp you wish to set them at...four of them (2 per mono) can keep the Robert Kodas operating as much as 10 degrees Centigrade cooler...so if you are operating at 50C-52C normally, then you are now talking 40C-42C.
Not only does it make it much better in-room...but even if you are setting them up in a separate room like you, Marty...running at a cooler operating temperature is going to keep the amps running much longer over time.
Thanks Lloyd. Will check them out for sure.Gents, as a Gryphon owner for 11 years culminating in the Mephisto stereo (and now the Robert Koda K160 monos...also pure Class A, 230 Watts into 4 ohms)...let me make a suggestion.
NF-S12A ULN
Marty/Lloyd,Thanks Lloyd. Will check them out for sure
Yes, I remember that. We have A/C. The quartet of fans were recently done at the suggestion of one of the designers of our audio isolation equipment. He put it together, and it has been a fantastic, utterly silent (only 8.6db per fan!)...and reduced the operating temp by 10C which I have to think is a good thing long term.I had to put a dedicated HVAC in my sound room to cope with the heat
Thanks Lloyd. I use those for any device where a fan is necessary, and you're right, they're quiet. The problem is that even with the fans, the heat builds up in the room. I have considered a clear acrylic "hat" - positioned slightly above the amps, collecting the heat, and exhausting it outside (e.g. with a quiet exhaust fan), but haven't done that yet.Gents, as a Gryphon owner for 11 years culminating in the Mephisto stereo (and now the Robert Koda K160 monos...also pure Class A, 230 Watts into 4 ohms)...let me make a suggestion.
NF-S12A ULN
Exactly. When one fine tunes and matches the bias of such amps, they need to insure they achieve a minimum internal temperature, and that's three different temperature points for the Mephisto monoblocks. Extracting that convected heat from the room is the key (unless it's winter time).while I can see some using fans on amps , I can’t see why there needed. any amp needs to get to a thermal state where it sounds best. Be it class a or a/b. In fact if one were to adjust an amps bias ambient temp is crucial in attaining the correct readings. if we use fans it may lead to a less sound since it may not be at operating temp. most amps even slide the bias to keep the amp at a given temp within a range.
Getting Better All the time... Better , Better, Better.I like the look of the Alexx V's much more than the Alexandria S2's. I would be surprised if they do not continue to improve over the next several hundred hours to exceed the Alexandria's.
Congratulations
