Alexx V press kit information from Wilson Audio Specialties
Alexx (L) Alexx V (R)
Difference Between Alexx and Alexx V
Our engineering team went through each of the critical sub-systems found in the Alexx® and
upgraded, or re-engineered, many of its components. Here are the highlights:
• Inspired by natural elements found in Utah one quickly sees more svelte lines in the Alexx
V™ like the XVX. The exposed “skeletonized” architecture allows an airy and openness
currently only found with the WAMM Mater Chronosonic® and the Chronosonic XVX®. Given
the open architecture gantry design, the gantry grilles are seamlessly attached via
embedded magnets, allowing for quick and simple installation and removal. Alexx Vs overall
size is only 1” deeper and 1” taller than Alexx Series 1 (same width as Alexx Series 1).
• The new 7” Alnico QuadraMag® developed for XVX finds its way into the Alexx V. This driver
is tonally rich and musically exquisite.
• New AudioCapX®-WA capacitors are now used throughout Alexx V crossover and are
uniquely wound at Wilson Audio® to our extremely tight tolerances. These custom
capacitors now add a new dimension of low-level resolution.
• All new Convergent Synergy® Carbon (CSC) Tweeter rear-wave chamber is 3D printed inhouse
with carbon fiber. The development of this unique design is greater high-frequency
extension, more linear frequency response, and better harmonic detail.
• First pioneered with WAMM Master Chronosonic, Alexx V features our latest cable
management system. Aiding not only the overall visual aesthetic of the speaker’s rearward
look, this cable management system offers an altogether superior solution to achieving the
perfect length of speaker cable for each of the upper modules as they are adjusted for
correct time-alignment. Included in this refined design is the illumination cross-brace with a
custom made Sono 1 Coolfall® light for ease of installation in dark environments.
• Alexx V is an extraordinarily adaptable design, including the XLF reversible woofer port and
independently adjustable upper modules. Greater ease of installation into a wider variety of
listening spaces allows music lovers to truly experience the ability of this system. Every
driver is now better aligned and more on-axis with the listener which provides outstanding
micro-detail and the time alignment accuracy is tighter at all listening positions.
• All X-Material enclosures with V-Material nested in strategic locations (top of the woofer, in
gantry cross-brace, and in the new Wilson Audio Acoustic Diode™ Spike). Vibration control
and upper module isolation akin to what is found in the Chronosonic XVX provides amazing
settling between the notes.
• Introducing the Wilson Audio Acoustic Diode. An all-new spike system launched with Alexx V,
which has been completely upgraded from our standard spike system, and features a novel
combination of austenitic stainless steel and V-Material. This coupling system was created by
Wilson Audio’s Special Applications Engineering® (WASAE) division and has superlative
vibration management that reveals far greater dynamic nuances across the entire frequency
spectrum.
• The custom built Wilson Audio binding posts, first appearing in Sasha DAW®, have now also
been integrated into Alexx V. Both banana plug termination and traditional spade
connections can be used with this binding post. This premier binding post offers a clean
signal path with an upgraded and larger contact surface area.
• There have been several crossover changes. With fewer components now in the signal path
we fine-tuned and modified the system for better Impedance and Sensitivity measurements
— From a minimum impedance measurement of 1.5 ohms (Alexx) to 2.0 ohms (Alexx V) and
+1dB more sensitive than Alexx Series 1. [me: 91dB sensitivity for original Alexx ]
• Gold lugs, which are a superior electrical conductor, are featured throughout the entire
product. Some places they can be found are within the crossover, connector plate contact
points, and resistor connections.
spectrum.
