Guys - I am not following why one needs or wishes for so many permutations of arms / carts or even just carts assuming same arm 4 times?
I can understand this “game” might be fun but I would find it rather distracting - I guess each to their own.
Imagine 1 favorite dish for every meal, everyday; vs 4 favorites dishes and possibility of having and trying many more along with sides and various desserts. There's a lot in high end audio to discover and enjoy, both for music and sound you can do that here at will.
david
Bill, it's a game not all of us are compelled to play.
I used to think that way. Once you realize how simple and fast cart changes can be with bayonet, the ability to use classic vintage carts and SPU's... it becomes addicting. Doing the same on fixed arms is not so easy pulling wire pins, switching out the cart from the head shell, ect and going through a more complicated and time consuming alignment process.
Hi David,
For me the “dishes” are the music itself - as in my collection of LPs.
Anyway - each to their own. Enjoy.
Are you using slotted headshells to avoid adjusting the tonearm pivot to turntable bearing distance every time you change the cartridge?
Most of my headshells are the SME (they sound great) so I adjust the sliding base of the tone arm each time. With the DB Protractor recommended by DDK it only takes 1 minute.
He's mostly using the fixed SME headshells, setting up alignment with the gauges I make is very fast and convenient.
david
Personally I find moving the base a lot easier for setup than the cartridge in a headshell and really miss that option setting up non SME tonearms.
david
Without the smiling Imoji I’m still guessing your post is tongue in cheek. The gauge eliminates using the cartridge for alignment and with straight side edges it can be done very quickly using the DB Protractor or equivalent.I agree with this point - it becomes as simple as setting a linear tonearm!
david
1 minute?
If you use a slotted head shell you don't have to make any adjustments once it is set. How is that not easier?
