Tang, when Ked doesn't know, he's unhappy. When he DOES know, he's unhappy. Brings new meaning to the line "if I didn't have bad luck, I wouldn't have no luck at all".
No when I know I move on 95% of the time
. . . It is not just about SS cleanliness but also the drive added to the chain. . . .
This is why I dropped my all-tube ideology and selected a hybrid line stage.
Sneak peek.
Tang
Mike, how power hungry are your speakers? And impedance curve? SETs can sound very different depending on the load and demand for more current. Just a thought. I have read many reviews of the ML3s while I built the Lamm website, and some of the magazine write ups at CES were not so positive. It seemed to be around the speakers they uses. Wilson's seemed to work, the Kharma's less so. Thoughts?when i use the term 'darker' when contrasting the ML3's with my dart mono's (and the VAC Statements), it's referring to a few related things.
the background is more candle lit, and less open, compared to diffuse daylight. so you did not see all the way into the edges of the soundstage. the darts allowed a less restricted view. colors are a bit deeper and denser. deeper than real? probably. softer too. more natural. too natural? maybe. a different version of reality.
the tonal balance is more liquid and textural, but not congested. the dart mono's are more transparent. both amps cover all the bases, only that the emphasis is different. the ML3's were not closed in on top as far as high end extension, but not nearly as open on top as the darts. it's rare for any amp to be as open on top as the darts but still have a natural tonality (not heard it).
in my system as long as the ML3's were in the comfortable performance envelop and the music did not get too large scale, it had an apparently linear sound. it was only when contrasted with the dart mono's that a different type of reality was represented. and i felt that when comfortable the ML3's were more linear than the VAC Statements, which always had a bit of soft, slightly thick, and warmed over presentation. with the ML3's disbelief was commonly suspended, the big VAC's rarely did that.
to be fair to the big VAC's, tube rolling might have made significant differences.
this is just what i recall in the context of my system. i'm sure others might view it different in different contexts.
and turning impressions into words is always a challenge.
my MM7 speaker's published specs are 97db, 7 ohm nominal, and there is powered bass below 40hz.
when i heard the ML3's on the Wilson Maxx's at CES (not sure which year), that was the 'darkest' i ever heard them (and the bass was quite flabby, but the sound was still magical). at ddk's i perceived them as slightly dark (less dark than in my own system, but his system was not at all familiar to me), and at Steve's the ML3's were a good deal less 'dark' sounding than on the Maxx's, but more dark sounding than what i perceived at my home on my speakers. my room is much larger and lively sounding than Steve's so debatable what is causing what.
but comparing a couple hours time at ddk's or Steve's to me living with them in my own system for 3 months it's hard to draw conclusions. just data points for whatever that is worth.
ML3's are my favorite tube amplifier i've heard when operating in it's design envelope. amazing sound. they left a permanent strong positive impression. not perfect at everything.
You never wrote about your impressions before
Just put a pointer to your lamm thread. In fact, save it, because you will be asked again
In fact Mike has been asked many times.I bet he is tired of repeating himself![]()
Steve I was being sarcastic
Thanks Mike, that is very insightful.it's ok, i like thinking about my time with the ML3's.
Yes, that is pretty much what Stereophile said at CES in 2016 I think it was. Maybe the big Kharmas are too hungry.Proper speaker system, amp and room matching is critical to building a great playback. I'd love to have the Lamm SET amp on my 96 DB speakers, but I'm not convinced that they can control the dual 15" woofers.
I've personally never liked the Lamm presentations in the large room at CES with the big Kharmas and the ML3. The smaller room with M1.2 on smaller Kharmas was always much more convincing to me.
I am betting that not only would they control the drivers but so also would sound darn good.
My speakers are 95 dB efficient and each speaker has a 13" woofer and a 15" subwoofer and there is just no problem
I never heard your system with the ML2.1's. Your system with the ML3's is absolutely fabulous I thought the bass was as tight and tuneful as I've heard. It would be interesting to hear the ML2 series on my speakers, hopefully I'll have the opportunity to do so one day.
. You could give me the best sounding Chopin record and it will be in my one time wonder bin.
/QUOTE]
Wow. That caught me by surprise. Here's a wonderful article from Terry Teachout on Chopin that might prompt some reconsideration.
https://www.commentarymagazine.com/articles/etude-brute/
