FYI:https://audioexotics.vanillacommuni...me-changer-on-mechanical-vibration-managementCertainly a novel approach , most interesting.
Currently testing a small platform:
For my part, and I suspect others , I would be interested in your considerations whenever you have spent some time with the platform .FYI:https://audioexotics.vanillacommuni...me-changer-on-mechanical-vibration-management
I will report what I hear.For my part, and I suspect others , I would be interested in your considerations whenever you have spent some time with the platform .
The twin knurled nuts are very fiddly to get properly tightened once the logo is facing forward. There's a very simple solution - ditch both the nuts and instead use a couple of wavy spring washers such as theseOne thing about the Gaia performance... the manufacturer says the footers must be oriented with their logo facing forward (or backward) for maximum performance. Most users see footers with threads and think, just screw them in (like I did when I first installed them).
Another simple solution, particularly for narrow speakers where stability may be a concern, is to fix these brackets to the base of the enclosure to which Gaias can easily be fitted once the supplied cones are removed. Also available in sets of 4... some speakers don’t have fittings to accept threaded footers
Yes, those are cool. Most users live with one capacity model from IsoAcoustics or Townshend without moving up or down but accommodating all capacities in one product is the Gold Standard... then you only have to be concerned with the footprint dimensions.Certainly a novel approach , most interesting.
I ditched the locking nuts and added a hand tightener on top - works great when using the Gaia's with outriggers. .The twin knurled nuts are very fiddly to get properly tightened once the logo is facing forward. There's a very simple solution - ditch both the nuts and instead use a couple of wavy spring washers such as these
A4 MARINE GRADE STAINLESS STEEL WAVE WAVY SPRING CRINKLE WASHERS METRIC M1.6-M20 | eBay
Find many great new & used options and get the best deals for A4 MARINE GRADE STAINLESS STEEL WAVE WAVY SPRING CRINKLE WASHERS METRIC M1.6-M20 at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Speaker Shockproof Bracket, Audio Speaker Foot Subwoofer Shockproof Spike | eBay
Find many great new & used options and get the best deals for Speaker Shockproof Bracket, Audio Speaker Foot Subwoofer Shockproof Spike at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
I use these brackets and spring washers with my heavy Avantgarde speakers.
That's a good solution too, but only if the outrigger is unthreaded and you have access to the upper surface. Anyone using existing spike threads could use my method. My own outriggers are threaded and I wanted to retain the top decorative covers so the wavy washers work best for me.I ditched the locking nuts and added a hand tightener on top - works great when using the Gaia's with outriggers. .
Interesting how many photos at Audio Exotics show Revopods being used together with the Wellfloat Delta feet for speakers, and with other isolation platforms (e.g., SRA) for components (example below). My Wellfloat component isolation platform floats freely with just a soft touch. Haven't tried the Delta feet but would assume they do the same.Have there been any direct comparisons between the Seismic Podiums and the Arya Revopods yet?
The Revopods are much less visually obtrusive and as such would have my initial preference. The Positive Feedback review of the Revopods didn’t like them on speakers however (https://positive-feedback.com/reviews/hardware-reviews/arya-labs-revopod/) and the Hifi+ reviewer seemed to use them only on components ( https://hifiplus.com/articles/arya-audio-labs-revopod-vibration-reduction-feet/), which pulls me more towards the Podiums. Price wise they would be comparable for the size and weight required for my new speakers. I have experience with the Gaia‘s on my previous speakers, but have gotten the impression these or not on par SQ wise with the other two products, based on feedback from others. Thanks for any input.
