Link, please?
There's a seach feature on ComputerAudiophile...
Link, please?
Was the noise measurement you showed the measurement of the PHY noise when the Regen is in use as compared to the measurement of the PHY noise when the Regen isn't in the chain?
Thanks. This is really, really strange. I had not realized that it came with a switchmode power supply. It is such a large brick I thought for sure it was linear:Measurements of the Regen w. SMPS as well as w. LPS done here (JohnW) - - > http://www.pinkfishmedia.net/forum/showthread.php?t=176975&page=83
the LPS Uptone Audio designed for eliminating the stock SMPS power supply for the Regens is the JS-2 .
I have 2 Regens and my JS-2 is scheduled to ship to me on September 30th. there is a back order to get on the list to buy one.
Yes, of course. So, what is it exactly I should be searching for? I find nothing relevant under "Swenson, measurement, Regen" or variations of that. Nothing also at the Uptone site.
Hi Mike:
I am almost positive the JS-2 was actually designed for use with the Mac Mini or similar.
Here is what they actually admit about the JS-2 with respect to the JS-2 and the REGEN:
"While it is true that our own JS-2 LPS makes a slight improvement for the REGEN, it is not a large difference and the REGEN sounds GREAT with just the selected stock supply."
Alex told me as a consumer, at $925 for the XPS, he would def. not see that pairing as cost effective. HOWEVER...I absolutely want to hear about what performance levels you are getting and
I admire you going the extra mile.
I hear you , I was just communicating what UpTone them selves said, and I assure Alex has a very impressive system himself where he does testing.I get different feedback regarding the JS-2-Regen pairing from 'others'. the total effect of any tweak is context related. at the top of the performance food chain small steps is all that is left to do. and eliminating every SMPS in the CPU seems like a worthy goal.
but the proof will be in whether I hear something significant. in the context of my investment in the CAPS v4 Pipeline, Teradak ATX LPS, and the Trinity dac + whichever dsd dac I end up with it makes sense.
I think it is also essential to point out that it is DAC dependent..which power supply will work..does it need the 5V handshake?You'll most probably get very good results with any equipment with a generic SMPS power supply: although the JS-2 may have been extensively used with Mac Minis, it is useful for any equipment that can use its supplied voltages.
The design was done very carefully. There was an initial much smaller but similar design by John years ago to strongly improve the Squeezebox devices. The JS-2 goes much further.
One of the things it deals with that people often do not think about is the noise re-injected back into the mains by the equipment you're powering.
There are a few things you can do for the Regen concerning power:
1. Use a better linear PSU for it than the stock Meanwell SMPS one
2. Use the stock PSU and combine it with an Sbooster adapter upgrade (third party)
3. Use the JS-2 PSU
4. Wait for one or two upcoming PSUs from Uptone (a couple of months or so if I remember correctly)
5. Build your own linear PSU + perhaps a John Linsley Hood Ripple Eater
Not sure if iFi's radically low-noise SMPS power supply is compatible with the Regen, but it it were, I would try it too.
3. Use the JS-2 PSU
It might be easier to head for John's profile and find his posts. It woud be a few posts back, perhaps a few weeks old, but not a large number of posts back.
In it, he talks about how he will need to build additional tools to allow proper measurements to be made.
So, in spite of your protest, the situation is still completely unchanged. There is nothing at all new on this subject, as you alleged.
Yes, the very same John Westlake - - > https://en.wikipedia.org/wiki/John_A._Westlake
