Aqua Formula - new upgrade, retrofittable!
The Terminator is just another dac of the month piece that will be worth nothing in 2 years. I think you deserve better Marc if you've waited this long.
FYI- I've heard the Formula and its def tube like in several aspects. I wouldn't say it's tonally thin at all. That said, I think it might be geared more for jazz and vocal listeners and ultimately wasn't for me.
Keith, I'm not in this game now yo keep upgrading.
If it is a "dac of the month", it's a bargain at £4K, and it'll be a keeper.
My Eera was prob a "cdp of the month" in 2010, yet in 2017 I'm still pleased as punch with it.
For me the Terminator if it checks out gives me a one stop solution with Zenith to streaming at not stupid outlay.
And with my room and grid so expressive, I'll know straight away.
Then it makes more sense to at least get a dac that is fully upgradeable.
This is a new one.
What's an upgradeable dac?
This is a new one.
PS Audio DirectStream is FPGA based for example and I believe the Terminator is as well.
You just download the new version of the OS and it re-programs the FPGA to (ideally) be better than it used to be. Also some DACs allow you to swap certain internal components. For example PS Audio DirectStream lets you insert the new so called Bridge II adapter and will then let you stream Tidal directly and also fully decode MQA. :D
Formula is upgradable in the same way I believe.
But, I'm not sure about the FPGA upgrades.
Has anyone got the update done?
If so please can they share their opinion on the SQ change.
We got back our Formula with the XHD upgrade 2 days ago
We tested SGM >Roon > HQP Player to Formula XHD with Lush USB cable to Bespoke TVC > VTL Monoblocks > Kef Blades
The Formula XHD was sitting on our latest most tricked out anti vibration platform
We ran our test tracks converted to 24 / 708 KHz and converted to DSD 256 (DOP)
The results were very impressive to our ears. We also transferred bit perfect 16/44
Our takeaways after 4 hours of testing after 18 hours of burn-in
- 16/44 playback definitely very competitive
- 24/708 PCM up sampling - lots of detail very well done, great precision. The sound reminds me of the Chord Dave when being fed 24/708
- DSD 256 upsampling. Compared to the 24/708 a huge leap in tonal richness and harmonic body. The texture of the voices and instruments are at a level that I have not heard before. Some might criticize the harmonic body as "euphonics" but for me it makes the performance extremely enjoyable. Trumpets to die for
On old well worn test tracks, new things I have never heard. The amount of information, sound stage size, depth, ambiance simply amazing
So definitely worth an audition, definitely a DAC that goes a long way further with the best upsampling you can muster
Hi Ed.
I’ve made a request via Sablon Audio/Mark for you to listen to this updated Formula on single ended as well as balanced.
All I need to know is whether the positives you’re hearing is equally apparent on RCA Out, or whether performance is compromised by not going XLR Out.
You’ll do me a big favour providing perspective to me on XLR v RCA, thanks.
Thanks for the update on the upgrade. When funds allow sounds like I'll move forward.
Also, I believe Mike said when he had the Aqua that it sounded better with XLR vs RCAs.
My q is not so much whether balanced is better.
I gather the vast majority of, if not all, dacs sound better balanced.
It’s whether single ended is decidedly worse, and loses any performance superiority the dac has.
For any component, balanced isn't always better, it depends on the designers' choice of implementation and preference toward sonic quality. I'm sure budget may also play a role for lower cost components.
Hyperbole police, please
I primarily listen to the CDT i.e. Diva. I Seldom use the computer for listening.
Would you think its worth upgrading then?
I owned the Aqua La Diva CD transport with my Formula dac. I could not recommend that transport more highly. great performer; and the transport remote also works with the dac for input switching. I still have a nice Sablon I2s cable I used which sounded great. the Formula/La Diva pairing has to be a great bang for the buck set up....for a CD spinner.....that also does the highest rez of PCM and DSD superbly.
Hmm, not getting the hyperbole comment tbh.
I thought my q was a pretty low key one.
Anyone had the chance to compare Aqua Formula xHD to Lampi GG?
Mike moved from GG to Aqua Formula, and Shakti found that Big 7 > Aqua > GG (before upgrades). I don't think anyone has compared xHD
Wow, the GG is $20k+ USD. Separate thought but has anyone compared the Lampizator Pacific to MSB or TotalDAC 12?
