You're absolutely right, I should have known judging from the sizeI think that's the Divin Majestic or someone delivered me the wrong speaker!![]()
Scary looking, and scary good sound.Looks a bit like a alien mouth..cool stuff ??
Surprised they’re on the outside of the Zu and not inside considering they’re 180 dispersion so beaming can’t be an issue. What was Arthur’s reasoning?Scary looking, and scary good sound.
Peter, haven't considered moving them onto the insides, will try that.Marc, Do these replace or supplement the speakers high frequency drivers? And did you compare to inside position of each speaker?
I'll let Arthur help w tech queries.Surprised they’re on the outside of the Zu and not inside considering they’re 180 dispersion so beaming can’t be an issue. What was Arthur’s reasoning?
There is a dedicated 'OFF' setting that fully disconnects the AirBlade units from the system. No need to remove the speaker cables. I just have a picture of a cutaway model handy to show the rear view with the two rotary switches (X-Over and Level) and the connectors (binding posts plus ground connector).Can it be turned on and off to see the difference?
For timing reasons (phase alignment) you usually end up retracting the AirBlade units to the back so that the diaphragm of the AirBlades is pretty much aligned with the tweeter of the main speakers (see below). If you would put the AirBlades on the inside you might get unwanted reflections but that's not a hard rule; we had plenty of systems where we had to put the units on the inside (due to space limitations) and it worked just fine there as well. Generally speaking I would say that outside placement creates a bit more open sound.Surprised they’re on the outside of the Zu and not inside considering they’re 180 dispersion so beaming can’t be an issue. What was Arthur’s reasoning?
