You may have mentioned it already, but I don't want to go wading, at what frequency do you cross over the Airblades?
Thank you.Don, Arthur informs me vertical dispersion is +/- 30°. Beyond that, SPL reduces rapidly avoiding ceiling/floor "bounce".
It's not so uncommon to have this effect RonYeahhh, that does not make any sense to me. But if you are happy, then I am happy for you!
Jack, they're working on multiple levels. I think their 180° dispersion is mitigating side wall effects. They're adding a certain ribbon-like transparency, air, speed and immediacy.It's not so uncommon to have this effect RonTypically when we change one end of the spectrum it can trigger a perceived change at the other end. It is very much like having complementary colors next to each other. Put yellow beside blue and at a distance it's green but close up the yellow looks brighter. Our brains are basically running pattern recognition non-stop. The tweeter plays counterpoint with the low bass. In active systems, bass definition comes back when the tweeters are turned on. Another of audio's cool phenomena
my bass tower adjustments (100% under 40hz) most definitely improved my high end extension. back in 2016 when i fixed my 30hz 10db room suckout and and then took 6 weeks to re-adjust my bass towers step by step with 4 bass tower amps each with 4 analog adjustments for each amp, i would constantly turn off the bass tower amps to check if the passive towers were better or worse by them selves. i quickly recognized the contributions of the bass towers to high end extension. at first i was surprised. it is the overtones from low frequencies that flesh out and balance the highs. one reason to aspire to full frequency coverage. more complete lows = more complete highs.It's not so uncommon to have this effect RonTypically when we change one end of the spectrum it can trigger a perceived change at the other end. It is very much like having complementary colors next to each other. Put yellow beside blue and at a distance it's green but close up the yellow looks brighter. Our brains are basically running pattern recognition non-stop. The tweeter plays counterpoint with the low bass. In active systems, bass definition comes back when the tweeters are turned on. Another of audio's cool phenomena
That first time was such a strange but cool experience right Mike?my bass tower adjustments (100% under 40hz) most definitely improved my high end extension. back in 2016 when i fixed my 30hz 10db room suckout and and then took 6 weeks to re-adjust my bass towers step by step with 4 bass tower amps each with 4 analog adjustments for each amp, i would constantly turn off the bass tower amps to check if the passive towers were better or worse by them selves. i quickly recognized the contributions of the bass towers to high end extension. at first i was surprised. it is the overtones from low frequencies that flesh out and balance the highs. one reason to aspire to full frequency coverage.
absolutely.That first time was such a strange but cool experience right Mike?
Jack, I'd been running my Townshend supertweeters for a few years ahead of the Airblades arriving. In truth, there's no comparison, the Airblades are a step change in performance.It really looks like a killer design. This looks like what our Townshends would want to grow into. Rest in Peace Max. Just sayin.. Pricey too. You do that much growing up you are gonna put on the pounds, pun intended. The Townshend is literally a toy beside that.
Tony Go is using them in one of his smaller setups.. but he said it also worked well with his Tidal La Assoluta. He said it is a must try experience.I want to try them. Arya shoot me a PM.
