@metaphacts - you are obviously closely associated with Wilson, and perhaps you are an employee, so let me ask the same question: how can two out-of-phase drivers be time coherent?
+1
So why no D'Appolito for Wilson? Dave spent his life pursuing the proper alignment in time of the full signal's arrival at the listening position. His pursuit has been measured and documented since Dave experimented with adjustable drivers mounted above his speakers some 50+ years ago. It has really been in the last 15 years, since academic studies bore out just how easily people hear time arrival differences and just how short those audible intervals are coupled with the WAMM Master Chronosonic project with the extensive research it entailed that Wilson designs began to take those intervals down close to, and in the case of the WAMM, below the audible threshold of the typical person. However, to accomplish this precision, the drivers must be capable of being pulse aligned at a given listening position (distance and ear height). But once the drivers move from a physically symmetrical array on the vertical axis, they cannot be termed D'Appolito by definition.
Bill
Interesting. Can you elaborate on this subject? As far as I see it, most of the time the digital is converted by a DAC and the cutter is analog driven.
Hi Keith,Bill, it was nice to meet you Saturday morning briefly (I was in the wheelchair hogging the room!)
follow up question - if time alignment is so important based on Wilson's studies, why invert polarity in the crossover?
Cutters use a DAC, yes, but the dots are connected in an analog fashion as it goes from one point to another. The cutter "fills" between in a mechanical way, where as a DAC has to do it electrically. Obviously you could probably design cutters differently to have slightly different sound profiles based on how it adjusts from point to point. You can adjust the cutter to not be sensitive enough to try and fill end information above the audio range as well, so you don't get tons of RF. (phono stages are meant to be fairly immune to it, and cartridges are necessarily good at reading it)
I was just trying to illustrate. Yes the cutter receive analog but it is a filter. Analog cutting of vinyl existed before we had anything remotely high sample rates. It simply doesn't translate the hash that a DAC on a CD player will.
I agree that listening isn't the same as measuring. However, we can measure coherence in time. The impact of time coherence is where the listening comes in.
I imagine the Daws are coherent sounding, as many speakers are. I've heard many Wilsons, and they don't sound particularly disjointed. But, to my knowledge, they aren't time coherent.
Wilson, like every company, has their marketing terms, and they seem to be eyeing time coherence as a feature of their speakers. I don't see how it's actually possible though. And again, they've been measured to be not coherent in time.
I'm just wondering how they can say they are, and people back them up, when the speakers are obviously not.
I'm in agreement with Ron. I've never liked a Lyra cartridge that I've heard at audio shows or show rooms. I never had one in my system. The sound always came off brighter and thinner than I liked.
We can also experience time coherence.
Let me ask you this: how do you think a time coherent speaker sounds? What are the sonic characteristics of a time coherent speaker?
Sidebar 2: Aspherical Group Delay
Wilson claims that its Aspherical Group Delay technology is as effective harmonically and texturally as it is spatially, helping to precisely reintegrate, at the listening position, the frequencies that have been separated by the crossover and sent to the various drivers.
To do this, each of the three drivers in the Alexandria XLF's MTM array can be independently adjusted fore and aft, as well as rotated on its polar axis. Of equal importance, once the appropriate position has been found, each module can be rigidly locked in place with tether bolts of various lengths, secured with wing nuts. Each module is moved along a pair of rails, each with a center notched track. There's one set of rails atop the woofer box, and one set each atop the lower-midrange and tweeter cabinets. There's also an assortment of spikes of different lengths. It's a major feat of mechanical engineering and precision manufacturing that needs to be seen to be appreciated.
All you have to do is measure the distance of each drive-unit from the listening position, and the height of your ears when you're sitting down, and Wilson's charts tell you into which numbered notch each spiked module should sit, and which length of tether bolt should be used to set the module's elevation. But no, you don't do any of this—your Wilson dealer will.
The goals are to time-align the drivers so that the combination of their outputs produces the equivalent of a single point source, and, by adjusting the modules' polar axes, to precisely focus the sound propagation on the actual listening position—not at a theoretical point a set distance from the speakers dictated by a design that might not suit the realities of the room. It's sort of like the difference between cameras with fixed and adjustable lenses."—Michael Fremer
_____
Taken from the Stereophile's review of the
Wilson Audio Specialties Alexandria XLF loudspeaker
Michael Fremer | Dec 28, 2012
For that particular speaker, read the review online, they use the Aspherical Group Delay Technology. Yes each driver's enclosure is adjustable to reach the listener's ears @ the same time, and with various adjustments in its rear, like phase, level, damping, etc.
_____
Dunlavy, Vandersteen, Thiel, Reference 3a, Tannoy, Quad, and few more employ "time coincident" technology with all the drivers in the same polarity and with individual driver responses arriving at the ears at the same time, sometimes called "time/phase coherent.
The crossovers in other loudspeakers are electrically phased tuned/corrected.
Some use low order crossovers (6dB per octave) to achieve best integration between the drivers. Speaker's design is an art, and it's also a science. Magic is obtained between our two ears.
Each speaker designer use more or less similar methods.
Which method is best? ...Vivid Giya G3, BeoLab 90? I have no clue; some use DSP, with FIR and IIR filters in their crossovers. Whatever sounds great is the aim.
I wouldn't mind give those a test drive, in addition to the Sasha DAW.
And a good setup in an acoustically tuned room is everything.
I can think of few speakers which would benefit and be @ ease to please two ears.
I can tell you what I've heard in time coherent speakers, versus what I've heard in all others. Though it also takes into account, speaker set up. Which I think is incredibly crucial, and even more crucial when it comes to time coherent speakers.
For me, when set up properly, I can see instruments and the space they're played in much easier. They're easier to listen to, even if they're very detailed. Images are denser.
Most speakers sound flat to me. Time coherent speakers tend to sound more dimensional. Less boring.
All this is saying is that Wilson Audio says that if you move the drivers around and into the correct positions relative to the listening position, time coherence is achieved.....
So we're back to, it's time aligned because Wilson Audio says it is. Even though the crossovers are high order, and the drivers start and stop at different times.
I've not read or seen anything that shows how the signal from their drivers actually arrive at the listening position coherent in time, even though they don't leave the speakers that way.
For that particular speaker, read the review online (...)
BTW, some recent reviews of the WAMM system include interesting comments on time alignment, including the influence of the driving amplifier.
