My dear man, you simply take my breath away. I know there are folks with exceptional hearing, you certainly must be one. In a way, I am glad my hearing is not so acute as yours! Electrical currents in interconnects are usually in the single digit milliamp range, if not less than a single digit, depending on of course input and output impedance. Where do you get your science to describe the mechanical effects at less than a milliampere of current on a three foot long wire, and then yet you can hear this. That is incredible for this good old boy to fathom!
Sorry, tomelex, no exceptional hearing here. Nor is it required. Like having eyes to see, it's really just a matter of having ears to hear. Not ears to see nor eyes to hear.
Tomelex, if I didn't know better, I'd almost swear you're trying to create a straw man argument here. Nowhere have I uttered a word specifically about any mechanical effects of current on a 1M long wire. The closest I came to that was my saying wire (assuming all wire) will vibrate with current passing through it. You wanna' try proving me wrong there, have at it. But there is a little experiment I intend try with the IC's with their potential to mechanically vibrate to see if I hear a difference. My suspicion is that I will, but I'll never know until I try, right?
In low amperage applications, could the vibrations not be seen with the naked eye? Sure. Does any vibrating wire, no matter how minute, have the potential to audibly affect the sound? Having very little experience with vibrating wire and their sonic affects but knowing much about the severe harm induced by under controlled vibrations in general, I would never want to leave any stone unturned, so I'd assume a big yes.
You ever play around with a tuning fork? You tap one of the tines lightly and put it up to your ear and for perhaps 2 minutes you'll hear an audible ring. But surely you don't think it stops after 2 minutes just because you can no longer hear it ringing, do you? No, the tines will continue to vibrate for at least another minute or 2 without at least my hearing a ringing sound. Shoot, for all I know maybe the tines might well go on vibrating for another 10 or 20 minutes. Don't you think if these tines continue vibrating at a microscopic level for say 5 minutes after the initial tap could induce sonic harm against a transistor or maybe an op-amp?
But your question leads me to believe that you probably think deep sub-terrainean bass frequencies are the only vibrations that can induce sonic harm into our playback systems. When IMO all vibrations across the frequency spectrum induce sonic harm. Therefore, IMO, all unwanted vibrations should be dealt with equally. Besides, once an unwanted vibration attaches itself to an object, it's source, frequency, and intensity ceases to matter.
You wanna' knit picking trying to discern which vibrations that potentially induce sonic harm are worth dealing with? Go right ahead, if you enjoy chasing your tail. But in my book all unwanted vibrations are potentially harmful, including any found in IC's regardless of how minute they may be. BTW, my only experience with attempting to deal with vibrations in wire were with my speaker cables last fall when I was surprised by some rather impressive improvements auditioning the Shunyata Dark Field v2 cable lifters that replaced my ceramic NoNameHiFi cable lifters. At that point, I made my own cable lifters out of some spare material with the intention to better control the speaker cables' ability to vibrate freely. As impressive as the Dark Field v2's were (I highly recommend them), my own DIY version was about double the Dark Field v2's performance.
But if you happen to know the threshold where unwanted vibrations cease inducing their distortive harm on wire or other objects, I'm all ears.
