The debate is on value of audio science in its formal listening tests and measurements it uses to determine audibility of distortions and fidelity. It says that if you think your equipment sounds better after warming there better be some measurement that shows it. If you tell me that with no measurement difference you clearly can hear improvements, then you are completely at odds with measurements and audio science regarding it. Unlike what you post above.
Your cause appears to be to cast doubt on validity of measurements to explain equipment fidelity. Don't see how you can do that in one breath and then turn around and give huge thumbs up to a post that copied the statements of a company making measurements and assigning audibility to it.
Amir,
this seems a bit lopsided
Measurements do show that amp behaviour can change in the first 1-2 hours, if going by just THD then the changes are small but it shows a behaviour change is occurring electronically/thermal operation window.
However it is fair to say then that while these are very small measurements it shows something is happening, therefore it makes sense to investigate further, with different measurements and with scientific listening tests, however as I said earlier and has been ignored by several if one does not have a scientific study (which this does not) then the only option is to fall back to engineering and the top experienced-knowledgeable engineers.
There are objectivists jumping the gun saying it is not actually happening and it is cognitive bias/confounding/etc because there are no scientific studies done, but they ignore the engineering community and measurement behaviour of quite a few amps; their response is THD is miniscule and so the amp behaviour is meaningless while ignoring electronically there is a change and that maybe further engineering investigation is required (that can bring us to notable engineers such as Nelson Pass and others who point out some amplifiers including SS do change between cold start and warmed-up)....
Now when you passed the final (where a lot of the issues were resolved such as db difference otherwise the test would had been voided) hirez vs cd quality ABX what were the measurements in regards to what was different and at what level were these variables?
I bet they were at a meaningless low value
If that is so, well one cannot ignore the measurements and correlation (at some point it should be modelled) with your test, but that is what a lot of that passing the ABX was about; it focused specifically on only one aspect of scientific study and that was a listening test, all the other aspects (measurement-correlation-modelling) are just as critical including the question I just asked.
Anyway looking forward to knowing more about the measurements and values with regards to your hirez vs CD abx pass.
Edit:
OK the above is bold because my point is already being taken out of context and my post completely skewed...
Sorry Groucho but you are taking it in the wrong direction, which is a bit annoying as it is misdirecting from what I was asking and mentioning.
Thanks
Orb
